5spd conversion
Old Jun 21, 2009 | 11:25 AM
ej8ster96's Avatar
Default 5spd conversion
so here is the deal, i have a 96 civic ex and im doin a 5spd swap, the trans is comin out of a 98 dx, i found a clutch pedal, brake pedal, master, and shiftlinkage out of a 94 civic, will it work?? alsoe will i need to change axles and will i have to change out the wire harness or can i work around it, and with the ecu that i have can i just use it or will i have to get a new one.
Old Jun 21, 2009 | 12:28 PM
cromeboner's Avatar
Default Re: 5spd conversion
I don't know about all the other parts but if you keep the automatic ecu you might get a check engine light
Old Jun 21, 2009 | 12:37 PM
ej8ster96's Avatar
what about the wire harness will i need to change it out
Old Jun 21, 2009 | 01:21 PM
JShull's Avatar
All that stuff will work fine man, the ecu will need to be changed though.
Your axles can stay the same.
You will need to change the IACV. And change a wire around on the plug that goes into the ecu.
Here's a link with some damn fine info that helped me do my auto to manual swap:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-96-00-auto-manual-swap-full-detail-44pics-1337459/
hondacurious
Engine Management and Tuning
Oct 27, 2013 06:13 AM
inline4
13
Oct 15, 2010 12:22 PM
devonic
Sep 12, 2003 04:48 AM
xX86CRXsiXx
13
Mar 28, 2003 05:53 PM
