is this possible???
Old Jun 20, 2009 | 07:13 PM
miguey310's Avatar
Icon2 is this possible???
is it possible to put a ep3 steering wheel on a ef??
Old Jun 20, 2009 | 09:06 PM
blazzer's Avatar
Default Re: is this possible???
sure anything is possible with car's
HOW to do it that what you need to figure out i can almost garuntee you there is gonna be some fabrication work invloved like example: cutting, welding, bending, yelling, punching.
but ya if your serious youd have to figure out proper wiring and mounting
i ahvent really run in to a thred or anything for doing somoething like this so deffently do some research on this. and idea is start by taking off you old wheel and trying guess fitting this one on. that could be a start as to help you decide what you need to do the get that wheel on
Old Jun 20, 2009 | 09:11 PM
sleepingciv's Avatar
that be a different look for sure might look cool.
Old Jun 20, 2009 | 09:47 PM
miguey310's Avatar
i i don't need the air bag or any of that jus the horn
Old Jun 21, 2009 | 12:13 AM
detuned's Avatar
my friend and i put an EVO9 steering wheel on his 2nd gen DSM. the size of the splines was completely different. we ended up welding it in. hopefully honda's a little more compatible.
Old Jun 22, 2009 | 12:10 AM
crxx's Avatar
im not sure if it's possible but worth the try.would like to swap mine out.
Old Jun 22, 2009 | 12:13 AM
crxx's Avatar
i put a steering wheel from an rsx in my db8. the spline on the db8 is smaller,but i just really tightened the nut down and it works fine.g/l
Ef4doorwagon
Mar 19, 2015 09:27 AM
miguey310
Dec 28, 2008 02:52 PM
2k3msp
Jun 23, 2008 10:26 AM
thenick
Mar 13, 2006 05:55 PM
