messed with the alt. now car wont do anything
Old Jun 20, 2009 | 12:59 PM
jnemci's Avatar
Default messed with the alt. now car wont do anything
my belt was loose so i adjusted the altinator. get in my car and try to start it but nothing turns on. my battery is fully charged and connected and ive checked all my fuses. anyone know what might be wrong?
Old Jun 20, 2009 | 02:18 PM
frank_el_tanke's Avatar
Default Re: messed with the alt. now car wont do anything
does it even crank? ignition lights on?
Old Jun 20, 2009 | 02:22 PM
FOMULA91's Avatar
so the car started before the alternator belt adjustment?
Old Jun 20, 2009 | 05:28 PM
Crossbreeder's Avatar
Check power going to the alternator itself. And grounds, always check our grounds. GL
Old Jun 20, 2009 | 06:24 PM
ek nine's Avatar
adjusting the alt should not have this out come, unless you super tighten the belt to the point where it won't let the crank spin (unlikely). check grounds and loosen the belt to see if it will do the trick.
Old Jun 20, 2009 | 06:37 PM
cuseikan's Avatar
Check your main fuse. If you touched the power output on the alt while messing with any of the bolts, then you more then likely popped your main fuse.
Old Jun 21, 2009 | 10:54 AM
jnemci's Avatar
when u say main fuse is that in the fuse box under the hood or you talkin about the main relay?
Old Jun 21, 2009 | 12:39 PM
90honduh's Avatar
main fuse is under the hood. and i would make sure the wiring harness is pressed in all the way and the ground is tight on your alternater.
Old Jun 21, 2009 | 01:46 PM
FOMULA91's Avatar
True. I once did it on the starter and blew the starter fuse 60A and it will probably happen to the alternator as will.... always remember to unplug the battery before working on cars....
Old Jun 21, 2009 | 06:11 PM
jnemci's Avatar
yes learned my lesson on taking the battery loose. ill work on the car tomorrow night and check the fuse and the grounds
Old Jun 21, 2009 | 09:12 PM
crxx's Avatar
sounds like a shorted fuse
Old Jun 22, 2009 | 08:21 AM
Black4thgenEF's Avatar
This.
sproket13
Aug 12, 2024 05:52 AM
crx18c1
Apr 19, 2007 04:35 AM
vw eater
Dec 3, 2006 12:03 PM
I_eat_Rice
Aug 15, 2005 04:15 PM
Proper
Sep 13, 2002 09:29 AM
