ABS Light Stays On - How to Fix?
Old Jun 20, 2009 | 11:07 AM
pcorad's Avatar
Default ABS Light Stays On - How to Fix?
97 ITR. My ABS light was throwing code 15 (right rear sensor). So I took off the right rear brake and poked around. The sensor didn't look damaged or have an excessive gap. I put it back together and now I get a constant ABS light. No DTC (codes). And, I can't erase this constant ABS light.
So helms says
1) check the 7.5 abs fuse. It's fine
2) Check for open in IG2 circuit. I'm not very handy with a multimeter. But the I stripped a bit of plastic off the No 11 wire on the 22P connector. Setting the multimeter to DC, I touch the red probe to the exposed No 11 wire, and the black probe to the body. The needle moves... Don't know what the meter should read... I could use some help with this step.
Assuming this step is ok, I go to step 3.
3) Check for short to body ground. The ABS light stays off, and the solution is "Check for loose ABS control unit connectors. If necessary, substitute a known good ABS control unit and recheck".
So, any assistance with step 2 would be appreciated (what values to set the multimeter tester at...2.5, 10, 50, 250? And what should I be looking for as a meter reading for "battery voltage"? 12v?
Or should I just try to find a known good ABS control unit and replace it?
Old Jun 20, 2009 | 11:21 AM
itr1244's Avatar
Default Re: ABS Light Stays On - How to Fix?
So helms says
maybe check the e brake cable. or see if you have any brake pads left
Old Jun 20, 2009 | 01:06 PM
pcorad's Avatar
Lots of brake pads. Check the ebrake for...?
Old Jun 20, 2009 | 05:41 PM
itr1244's Avatar
calibrate the e brake cable...
check for the brake fluid level as well
Old Jun 22, 2009 | 12:12 PM
pcorad's Avatar
Plenty of brake fluid. The ebrake seems to work fine.
How does the ebrake cause ABS lights to come on?
Anyone have a known good ABS control unit lying around?
Old Jun 23, 2009 | 02:46 PM
pcorad's Avatar
Fixed.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/ecu-sensors-troubleshooting-multimeter-2560243/
krazyk606
Jun 15, 2009 07:32 AM
Undercover_Skank
Mar 15, 2004 07:13 AM
redteg1
Aug 18, 2001 02:42 PM
Nighthawk GS-R
Aug 5, 2001 11:04 PM
