help me measure piston to deck clearance
Old Jun 20, 2009 | 07:25 AM
itr_henrik's Avatar
Post help me measure piston to deck clearance
I'm trying to figure out what my piston to deck clearance is on my new built JGE block that I just received. I'm measuring this with a dial indicator I put the tip on the edge of the cylinder zeroing out then slightly turning the indicator so the tip lays on the piston flat surface. Then rotating the crank until I get the least clearance. On cylinder #1 I got 0.004" on the intake and 0.014" on the exhaust side. Now what is my actual clearance? Should I average the two different values? Or am I doing something wrong here? Is this OK to measure different clearances on the different sides? The pistons are CPs, BTW. Any input is appreciated.
Old Jun 20, 2009 | 08:27 AM
h224thgensedan's Avatar
Default Re: help me measure piston to deck clearance
Is your deck level when you are measuring (not tilted more to one side)
Old Jun 20, 2009 | 10:08 AM
itr_henrik's Avatar
No, it's not. So that's what's messing up my clearances. Thanks for the advice, I'll level the block and then remeasure everything.
Old Jun 20, 2009 | 12:05 PM
PyroProblem's Avatar
Depending on the piston to wall clearance, the piston may "rock" slightly giving you different readings...
Not absolutely sure of the correct way, but I would go with the smaller #'s just to be safe...
Old Jun 21, 2009 | 08:11 AM
Has your block been decked. Wonder if it has been if it has a slant to it? Not sure just an idea.
Old Jun 21, 2009 | 10:21 AM
itr_henrik's Avatar
Yes, the block is decked. Piston to wall is 0.0030".
I leveled the block and remeasured everything. These are the readings I got.
Cyl INT EXH
1 10 11
2 17 16
3 10 18
4 8 8
The numbers are thousands of an inch on the intake and exhaust side. I repeated several times and got the same readings. Now someone please help me decipher these numbers. Why do I get so inconsistent readings in the different cylinders? I'm totally lost here...
Here's how I'm doing it
Old Jun 22, 2009 | 11:35 AM
lohatch's Avatar
either your indicator is getting moved/bumped.
your block is not flat.
your crank has 4 different strokes, your rods have 4 different lengths or your pistons have 4 different compression heights.
i'd guess option #1 though.
with your indicator on the pistons rock it and use the tightest reading
ls_bitik
Oct 17, 2007 10:43 PM
got wide
Sep 4, 2007 03:55 PM
Rosko
12
Mar 17, 2007 04:09 PM
koolaid3246
May 2, 2006 06:25 AM
