Which is better for motor build?
Old Jun 20, 2009 | 02:00 AM
sgriffiths's Avatar
Default Which is better for motor build?
Hello all. I was inquiring as to what everyone feels is a better motor to base a build off of. a B20 or the single cam vtec. Any idea what has a stronger and more reliable potential? Not looking for ridiculous power, but something that can be a daily, and get the job done. Thanks for your help.
Old Jun 20, 2009 | 03:11 AM
Matt93eg's Avatar
Default Re: Which is better for motor build?
Get the B20 and research a B20/VTEC and Build that.
Old Jun 20, 2009 | 09:07 AM
Bwill9886's Avatar
Both engine types have the potential to make power. The difference is power delivery.
The B20 will net you more low end torque than most single cams (some F series make good torque, but its not down as low as the B20's).
So it comes down to where you need your power the most.
Old Jun 20, 2009 | 09:11 AM
NightCat's Avatar
B20 ftw.
Built D's tend to not last so long.
Old Jun 21, 2009 | 02:39 PM
sgriffiths's Avatar
bump
Old Jun 21, 2009 | 02:48 PM
Benny-coupe's Avatar
Originally Posted by NightCat
B20 ftw.
B20's seem to be few and far between build correctly over my side of the water ,only a few seem to be getting built for Dc2's over here ,alot of eg;s have D15 turbo setups over here and can run quite happily but only if mapped correctly ,b20 in my oppinion is a great build but not many are high revving in the same section as a B18c .
Old Jun 22, 2009 | 10:39 PM
sgriffiths's Avatar
bump
Old Jun 22, 2009 | 10:47 PM
xxblazexx's Avatar
they'll both work but the d-series is cheaper and is alrdy in your car.
the only weakness is its con rods. though since you dont want crazy high power levels it shouldnt be a problem
Old Jun 22, 2009 | 10:51 PM
nickolasj1's Avatar
do the d series... b20 is ment to spin that quick... and d series is cheap lol
Old Jun 22, 2009 | 10:52 PM
nickolasj1's Avatar
IS NOT MENT TO SPIN THAT QUICK my bad
Old Jun 23, 2009 | 12:15 AM
jdmjunk93's Avatar
New User
get the b20...i have a 93 ex with a stock b20 swap. it's my daily driver, and i love it....quick enough for fun...but settled enough for a d.d.
Old Jun 23, 2009 | 11:08 AM
sgriffiths's Avatar
bump
Old Jun 23, 2009 | 11:13 AM
98civdx's Avatar
Master Detailer
either, they are both great motors.
are you planing do b20/vtec or just b20?
Old Jun 23, 2009 | 11:32 AM
hybridmiklo's Avatar
How bout you just boost the d-series for the same price it would cost to swap in the b20 and make 60 more hp and torque? Make sense?
Old Jun 23, 2009 | 01:43 PM
dannyzook's Avatar
New User
Just put in a Type-R Japan Spec 98, it has loads of power and is fun to drive. I am waiting to tune it to see if it will be faster. I think it is going to be more reliable than the d-serires turbo I had.
Old Jun 23, 2009 | 04:53 PM
sgriffiths's Avatar
I understand the type r is a better build than what I am doing, but it is because it is too expensive. What are the differences when doing the stock b20 versus the b20/vtec?
Old Jun 23, 2009 | 05:12 PM
boost and bass's Avatar
if type r is to expensive then scrap the b20 build for bang for buck a d-seires is king and can esaily be very powerful and very reliable if the job is done right, if you have enough money b-series have obviously more potential but you can have a built turbo D for the price of just a swap
Old Jun 23, 2009 | 05:17 PM
And btw the a b20/vtec is like an ls vtec its using a b20 block with a vtec b series head it can be a good motor but needs to be tuned properly to be reliable and the price of all the parts plus water pump, head gasket, timing belt etc. plus tune a good tranny it can be very pricy
GoLowDrew
Jun 12, 2013 01:46 PM
tundra2000
Dec 15, 2010 02:12 PM
smackey
19
Jan 4, 2009 04:49 PM
VegaS10
14
Nov 14, 2005 04:25 AM
Bullet50
Sep 17, 2002 02:30 AM
