type r rear caliper
i think my rear caliper went bad because the tire is hard to spin and stinks alot like brakes. wonder if i could get another caliper that is the same from another honda or acura, or it has to be a typer r caliper. any comments, need help. or how to fix it.
You can use the bracket from the RSX, but the RSX e-brake connector is the wrong style. I have 2 rear RSX calipers in a box, because I could only use the brackets. I used calipers from an 01 Prelude. I had to bleed them off of the rotor, because of the location of the bleeder valve.
No need in buying a new caliper. You can still buy rebuild kits from
Acura for less than $20.
Brake caliper rebuild kits for the ITR.
Front: 01463 - ST7 - R00
Rear: 01473 - SV4 - 000
