need help...over heating issue
Old Jun 19, 2009 | 07:45 PM
mf10_eg88's Avatar
Default need help...over heating issue
my car is over heating. my overflow tank is filling up with hot coolant everytime my car is warm. my temp gauge reads normal when its overflowing with hot coolant. my fan dosent come on either. it seems like the the coolant isnt circulating. my top radi hose is warm but my bottum one is cool. i took the thermostate out and it still did the same thing...any suggestion what i should do next or any suggestion of what the problem is?
Old Jun 19, 2009 | 08:05 PM
hOnda_hiEn's Avatar
Default Re: need help...over heating issue
maybe cause the fan doesnt come on..?
Old Jun 19, 2009 | 09:13 PM
waaBAAH's Avatar
your building up pressure in yoru system causing the radiator cap to open which in turn is filling your coolant resovoir.
sounds liek a head gasket issue and the exhaust gases are creating this extra pressure.
Old Jun 19, 2009 | 09:31 PM
EG-4-LIFE's Avatar
When was the last time you flushed your block? If your lower hose is cool when your top hose is hot then the water isn't circulating. Try flushing the block then fill it with coolant and water. Also, your fan doesn't turn on cuz either your sensor doesn't work or the fan doesn't work. Check them both.
Old Jun 19, 2009 | 11:55 PM
mf10_eg88's Avatar
i manualy wired it to come on too, but still same thing.
Old Jun 19, 2009 | 11:58 PM
mf10_eg88's Avatar
its a swap. i'll try flushing it. i also did a wire tuck too but i soilder everything and no check engine light.
Old Jan 16, 2012 | 06:46 PM
mf10_eg88's Avatar
fixed it... i just bleed the hole coolant system for air bubbles and it circulates fine now, also my fan comes on now too
Old Jan 16, 2012 | 06:49 PM
Former User's Avatar
Almost 3 year delay in a response - hope it didn't take all this time to solve the problem.
Old Jan 17, 2012 | 12:29 AM
92civicsedan's Avatar
my car was having simular issues my upper rad hose was over pressurized and my lower hose was cold and no pressure my oil was clean and anti freeze was clean too changed thermostat and rad cap..lower hose still cold but fans work and its circulating...maybe i need a flush?..
sinisdeadly
Aug 12, 2014 11:47 PM
Rein4st
Apr 7, 2012 11:17 AM
Jmumblez2001
Feb 16, 2007 09:07 PM
mrx
Jul 4, 2006 07:44 AM
dkdjlf
Aug 14, 2003 10:34 AM
