problems with b20b swap
just got my b20b swap in my 95 teg.
im throwing a code for a vss. easily solved.
they clutch has been slipping since it was put back in. pulling into my street the other night the car would not engage in gear. had the clutch pushed in then let off while it was in neutral...then the car died. so i started it pack up. i was on a little hill so the car rolled back. then it went into gear and stopped rolling with the clutch in. (did it in all gears.) any suggestions? the clutch is a shitty autozone one just b/c i needed to get the car mobile again.
also, clutch slips when i hit gears. after i let off it sits and about 6 grand and then grabs. and even while just moving pushing gas it revs up then drops.
im pretty sure i just got a shitty clutch but j/w if anybody has any other suggestions before i go put a new one in....
b20b motor (+ b20b head) with b18b tans.
thanks for the help
thanks for the help
Seems like the clutch is giving out. IT would be best to just change out the clutch, with a new one. I was going to suggest that it was the pressure plate, but either if you have to replace the pressure plate or tighten(if loose), you might as well just replace the whole darn thing.
stc876
Transmission & Drivetrain
13
Dec 14, 2015 02:55 PM
99-coupe
Aug 16, 2014 05:54 AM
phokingthai
Jul 4, 2014 01:53 PM
nostreble
May 11, 2006 12:35 PM
