Fuel Gauge working funny?? HELP!!
Old Jun 19, 2009 | 05:51 PM
aquito's Avatar
Default Fuel Gauge working funny?? HELP!!
so i searched and didnt find any answers that could help me.....
heres my problem..i have a 95 LX..my fuel gauge is stuck in F almost all the time...if i let the car sit for a day and has less than half a tank the neddle goes down, but as soon as i start driving the car it goes up to F...and if the gas tank is almos empty the gas neddle goes down...but as soon as i put like 5 bucks of gas it goes to F again...
what can it be?? the gauge? inside the fuel tank??
thanks in advance ........
Old Jun 19, 2009 | 05:57 PM
shailoche's Avatar
Default Re: Fuel Gauge working funny?? HELP!!
It is probably the fuel sender. There is a certain voltage that must be sent from the fuel sender in the tank to the fuel gauge if it isn't the correct voltage then you get always full or always empty. Check the wiring from the fuel sender and see if it is alternating voltages...if it isn't then the fuel sender in the tank is bad and you have to replace it. If the voltages are fluctuating correctly then it could be the dash gauge.
Old Jun 19, 2009 | 06:31 PM
Integra4lyfe069's Avatar
yo sup man I have this EXACT same problem in my 1996 honda civic SI. ALSO symptoms of mine is bogging out almost and losing almost all power like it miss fires as im riding along, but hitting the gas seems to straighten it out. i couldnt figure it out either and i still have this problem so between me and you lets get this fixed aye? :p
Today i have my back seats out and the cover plate off my fuel send unit/gas tank area. the area was rusty/corroded/all dirty, i took flat head screw driver to it and loosened all the dirt grime rust and everything else then vaccumed it all out. I disconnected the wire harneses from their clips, and inside the clips there was all kinds of gunk and white grease so bad I couldn't even see the solinoids or connectors inside lol. At that point it was getting dark so i left it for today. Tomorrow I'm going to try and clean those up and try and remove the bolts holding the sender sender unit in place... I don't know what I'm getting into here I've never seen the inside of it before or even the sender unit itself before. Any pictures or help of remove or w/e on this process if any1 has it would be greatly appreciated.
Also Ive never usaed a volt meter before or know how to test wires for voltages could anyone point me some info or tips on how to check/where to check these wires for the volts? thanks in advanced.
Old Jun 19, 2009 | 08:15 PM
hOnda_hiEn's Avatar
could be a bad floater on the fuel pump.. mine did the same thing on my integra before.. replaced the whole fuel pump and fixed it..
Old Jun 19, 2009 | 10:03 PM
Korean99EK's Avatar
Check your floater...buddy had the same problem stayed at fuel everytime he drove. Fixed it and went away.
Old Jun 19, 2009 | 11:20 PM
eg grom's Avatar
Integra4lyfe,
I'm not sure if you are having the exact same problem that I once had, but your car seems to be acting very similar. It might be that your main fuel relay is going bad so if you get the chance, check it with a volt meter to make sure it's working properly. It's located under the driver side dash over by the fuse box
Old Jun 20, 2009 | 09:39 AM
really? ok ill pull out the relay today and have a look but my problem is ive neverused a multimete or a volt meter and i dont know how to use one or what to do, im gonn go buy one right now though so if u could possibly telle me what to do with it and how to test it thatd be great.
also is a volt meter better then a multimeter? or what . lol
Old Jun 20, 2009 | 12:50 PM
bump any1 ?
Old Jun 20, 2009 | 05:00 PM
aquito's Avatar
how do i remove the fuel pump? is that underneath the back seat? would i be exposed to the fuel tank if i take it off? cause that could be a little dangerous i think....can i only change the floter on the fuel pump or i have the change the whole fuel pump?
i really think is gonna be the floater cuz as soon as the car starts moving the fuel goes to F...i can have the car on and the neddle is ok..it goes to F when i take a corner or something like that...
lets get this problem fixed for two people....thanks guys
Old Jun 20, 2009 | 05:27 PM
i have my back seats out and the silver plate off, opening that plate only reveals the gas tank and the wires etc, takign it off wont expose the inside of the gas tank tho only the outside which is totally fine.
im currently testing my wires for voltage for the sender unit, I aswell would liek to know which one the fuel pump is and which one the fuel sender unit is because i see two below the silver plate
Old Jun 21, 2009 | 10:32 PM
eg grom's Avatar
http://www.2carpros.com/forum/automo...00_gauge_1.jpg
Integra4life,
I forgot where I saw the specs for the main relay and which ports to check, but I'll look around and see if I can find ya some directions...
Old Jun 23, 2009 | 07:06 PM
thanks man any luck ?
vrrodri
Jun 29, 2011 05:32 AM
sgraham01
Jul 8, 2010 08:42 AM
Jar-Head23
Jun 5, 2009 08:36 PM
macdaddydelux
Honda Motorcycles
Oct 10, 2007 01:43 PM
