honda2.2 liter engine head bolts do they need RTV
Old Jun 19, 2009 | 05:35 PM
critt's Avatar
New User
Default honda2.2 liter engine head bolts do they need RTV
A friends 2.2 liter engines head gasket was replaced and now it smokes and has antifreeze in the oil. I believe that some of the head bolts need RTV on them.
Old Jun 19, 2009 | 05:47 PM
soon2bdropped's Avatar
Default Re: honda2.2 liter engine head bolts do they need RTV
what was the reason why the headgasket was changed in the first place was it because of the same concern? there could be a number of things. maybe improper torquing the headbolt.. maybe defective gasket.. maybe warped head/block. need more info.
Old Jun 19, 2009 | 05:53 PM
GhostAccord's Avatar
There are no head bolts that require RTV sealant.
x2 on the more info. Why was the HG replaced?
Old Jun 19, 2009 | 06:09 PM
tamadrummer1120's Avatar
agreed. and maybe it is leaking somewhere else. intake manifold gasket too possibly?? Defintely need more info. And aren't head bolts T-T-Y anyhow?
Old Jun 20, 2009 | 05:40 AM
accord99power's Avatar
whats T-T-Y? just wonderin.
Old Jun 20, 2009 | 07:00 AM
It means torque to yield and that they are to be used only the one time. Honda head bolts are not TTY. They can be reused. Although a good practice would be to replace them.
Old Jun 20, 2009 | 09:49 AM
nus_dogg's Avatar
Did you guys torque them to specs? Could also be warp head or block. A defective headgasket mentioned earlier could be the culprit too.
Old Jun 20, 2009 | 10:09 AM
so easier put, to oem torque specs? or is to yield mean something else. thanks ghost for the info.
Old Jun 20, 2009 | 10:20 AM
Torque to yield is the method of tightening a fastener so that a high preload is achieved by tightening up the yield point of the fastener material. To do this consistently requires special equipment that monitors the tightening process. Basically, as the tightening is being completed the equipment monitors the torque verses angle of rotation of the fastener. When it deviates from a specified gradient by a certain amount the tool stops the tightening process. The deviation from a specified gradient indicates that the fastener material as yielded.
The torque to yield method is sometimes called yield controlled tightening or joint controlled tightening.
I know some head bolts for some vehicles are TTY, but I did not know if the Accord's were, never had to pull the head off yet.......*crosses fingers* *knock on wood*
Old Jun 20, 2009 | 10:22 AM
ahhh got it...... haha. thanks man.
Old Jun 20, 2009 | 10:24 AM
not a problem.
twocross
Feb 23, 2011 03:07 PM
CYBERBASS
Honda Civic (2001 - 2005)
Apr 27, 2010 07:11 AM
primerpimpin
Oct 23, 2009 06:49 PM
jdm-spec-eg
May 22, 2003 02:00 PM
