what is this and where does it go please help
Old Jun 19, 2009 | 03:47 PM
kornkid21792's Avatar
Default what is this and where does it go please help
Old Jun 19, 2009 | 04:06 PM
dagle's Avatar
Default Re: what is this and where does it go please help
wait is that a hard line?
Old Jun 19, 2009 | 04:30 PM
slow96lude's Avatar
im fairly sure it goes to the stocl intake tube. i had to pull it off mine when i removed my tube
Old Jun 19, 2009 | 07:40 PM
duanes's Avatar
Mine connects to the intake tube (before the throttle body). There doesn't seem to be much effect plugged or unplugged. I would either clamp it off... or if you are feeling handy, just put a vacuum nipple on the intake right there. I think it is used to detect and adjust the fuel mixture under high differential vacuum situations - ie, drop the throttle closed at 5000 rpms.
Old Jun 19, 2009 | 09:29 PM
Hawkze_2.3's Avatar
That is the fresh/filtered air supply for the starting air valve. The stock intake or a good aftermarket intake will have a nipple for it. Leaving it open is fine, or you can trace it back to the valve and remove it there. Or just remove the whole valve, it won't really matter....
Old Jun 19, 2009 | 10:57 PM
o ok cool thanks
fuzzysig
Dec 2, 2016 01:11 PM
Herro Panda
Aug 11, 2012 09:35 AM
Accordin2me
Aug 5, 2010 03:02 PM
sony224422
Jul 21, 2006 02:43 PM
lude-tec
Jan 18, 2006 09:19 PM
