ignitor fails repeatedly
Old Jun 19, 2009 | 03:01 PM
famou55TAR's Avatar
Default ignitor fails repeatedly
im at a loss. im going through ignitors left and right. has anyone run in to this problem.
Old Jun 19, 2009 | 04:23 PM
KWayRacing's Avatar
Default Re: ignitor fails repeatedly
are you using OEM igniters? When you say left and right explain? Make model and year would be helpful. ALso, do you have any aftermarket ignition devices(MSD). More info please?
Old Jun 19, 2009 | 05:39 PM
famou55TAR's Avatar
1990 accord. i tried oem. and no i dont have aftermarket ignition
Old Jun 19, 2009 | 07:27 PM
stereo69's Avatar
replace the coil and ignitor as a set and check the the distributor bearing for wear ( red dust inside the distributor and cap ) if it does replace the whole thing.
Old Jun 20, 2009 | 07:57 AM
bsivoljr's Avatar
YEAH WHAT HE SAID^^^If the coil is bad it can send the wrong voltage to the ignitor everytime and blow it. Take it to autozone and have them test the primary voltage and secondary voltage of the Coil. they can also test the ignitors. bring your haynes and look at chp5 I think electrical. If primary and secondary are not within spec even the slightest bit it can cause a fail from the coil throughout the electrical supply. Coils and Dizzys usually fail together like bad breakups
Old Jun 21, 2009 | 03:59 PM
famou55TAR's Avatar
i replaced the dizzy assem today. starts and runs. hopefully it will start working for me. thanks guys.
Nerologic
Jan 29, 2007 03:56 PM
ActiveAero
Sep 16, 2006 11:21 AM
Skank_aSS_Dara
Mar 24, 2005 09:21 AM
mingchi96
Dec 21, 2002 01:40 PM
Dee
Jan 3, 2002 10:49 PM
