Skunk2 Pro-S Coilover Kits - FREE Skunk2 Lower Tie Bar : While Supplies Last!!
** You read the Title 110% Correct!! For a Limited Time Only with all Purchases of a Skunk2 Pro S Coilover Kit you will receive a FREE Skunk2 Lower Tie Bar **
Import DPS is doing one of its very first insane steals of the Summer. With every purchase of a Skunk2 Pro-S Coilover Kit we will be giving you a FREE Skunk2 Lower Tie Bar. The Skunk2 Pro-S Coilover Kit is one of the best on the market and hands down the best beginner adjustable suspension. The quality is a hit every time and for the Street this is a deal you will not want to miss out on.
Sale lasts till the end of July!!
** Questions we know people will ask **
1. How do I order this combo? - Its simple, just use the links provided below and begin to order. Order your parts like normal and submit it with Fedex Ground Shipping or the Shipping Method of your Choice. We will then combo your deal out and discount your Tie bar on the backend of the order processing.
2. Can I just call in and order? - Of course, just call our sales team an mention your from Honda-Tech and would like to order the combo and we will do the rest.
3. What colors do you have in stock for the Tie Bars? - At the moment, we have plenty of these in stock. However, Supplies will run out. If you ordered a color that we do not have in stock, we will contact you to substitute or give you an ETA on when it will be coming back in.
** Order your Skunk2 Pro S Coilover Kit Here -> http://importdpsonline.com/skunk2/sk...s/g-50686.aspx
* MFG Info - Skunk2 PRO-S
PRO-S dampers are the perfect basic high-performance full coilover suspension. PRO-S dampers are designed for drivers who are seeking an integrated coilover and shock set-up. PRO-S dampers feature pre-determined precision valving and carefully selected springs that are designed to dramatically improve handling performance by significantly increasing corner grip and reducing body roll, allowing the driver to feel greater control and stability at all speeds. Skunk2 springs are CNC-wound using the highest quality SAE9254V spring steel. Each spring is designed to optimize the balance between performance and comfort, and are custom matched to PRO-S dampers. PRO-S dampers provide an average drop from 1” to 3” for a sporty yet aggressive look. The PRO-S suspension offers dramatic improvements to handling while retaining an entry-level price.
* Dual Tube Design
* Non-Adjustable Precision Valving
* Shortened Shock Body and Stroke
* Adjustable Ride Height
* One-Piece Machined Bodies
* Uses Factory Upper Mount
* Some Kits include Forged Mounts
* SAE9254V Racing Springs
** Order your FREE Skunk2 Lower ARM/Tie Bar Here -> http://importdpsonline.com/skunk2/sk...r/g-50692.aspx
* MFG Info - Skunk2 Racing Rear Lower Arm Bars are constructed of aircraft quality AL606 and are designed to tie into the rear suspension with easy installation. Skunk2 Racing’s Lower Arm Bar increases chassis rigidity and performance handling characteristics by connecting the suspension points to prevent chassis distortion while under hard cornering and aggressive driving. There is even a more dramatic improvement in rear suspension performance and feel when used in conjunction with Skunk2 Lower Arms, Rear Camber Kits, and Rear Strut Tower Bar. Available in clear or hard anodized finishes and includes all mounting hardware.
We accept Visa, Mastercard, American Express and Discover on our Website. Cash local pickups also welcome. If you have any questions, please feel free to contact us at 866-703-8794 or send us a pm.
Don't forget to check out Skunk2s new Flat Black Limited Edition Lower Control Arms - Good in Stock Now - http://cms.skunk2.com/id/185/SKUNK2-...-CONTROL-ARMS/
Thanks
Import DPS
www.importdpsonline.com
* Dual Tube Design
Thanks
Import DPS
Friday Bump!! Thanks for all the orders over the week. We appreciate the business and loyalty!
Import DPS
Import DPS
Bump!! Getting ready for the Pan Americans. Please note Import DPS will be closed tomorrow, Friday the 17th at 2PM EST.
Back from the Pan Ams. Most orders are all shipped or at least have an order update. We greatly appreciate your patience while we got back in gear today.
