engine swap wierd turn over??
Old Jun 19, 2009 | 10:17 AM
circapunk's Avatar
Default engine swap wierd turn over??
i just swaped in a d16z6 and we go to turn it over and its starts to crank over and then it stops like something is stoping it from countinuing to turn over. you think my starter is pooched ot something??? please help
it was doing this at first so we waited a few min tryed again had the car started for like 1 min then turned it off. to check over somethings goto turn it over again starts doing it again.
maybe grounds?? any clue
Old Jun 19, 2009 | 10:25 AM
Former User's Avatar
Default Re: engine swap wierd turn over??
Yeah, you might have a loose transmission ground connection. Also check the two wires attached to the starter. Then check the safety starter switch at the top of the clutch pedal. Also consider the ignition switch.
Old Jun 19, 2009 | 10:31 AM
92bseries's Avatar
cant forget thermostat ground
Old Jun 19, 2009 | 10:36 AM
That's a really important ground but I don't think it's needed for the starter motor to work.
Old Jun 19, 2009 | 10:54 AM
92bseries's Avatar
this is tru, but if its not connected the car wont run at all, or if loosely then maybe a problem like this guys
vteckills40r
Mar 13, 2010 11:21 PM
Offspring EK
22
Dec 9, 2009 04:55 PM
turbo-crx
Aug 3, 2008 12:02 PM
sohctodohc
Oct 18, 2006 09:08 PM
AKUFC
Sep 10, 2003 05:11 PM
