What injector size would you guys run on a high compression build?
Old Jun 19, 2009 | 09:57 AM
EBEATS's Avatar
Default What injector size would you guys run on a high compression build?
I buliding an high compression gsr motor.
I have ctr pistons with ctr cams in a 99 gsr with a full port on the head.
I wanna run that Ethynol Gas so what injectors do you suggest I should run?
Like what size?
Also I bought some ARP Rod bolts for my build and the machine shop is saying they arent the right ones?? I guess I need the 9mm ones for my connecting Rods, unless you guys have had a different experience with the 8mm ones on a GSR build??
Any Help??
Old Jun 19, 2009 | 11:16 AM
EBEATS's Avatar
Default Re: What injector size would you guys run on a high compression build?
any one??
No opinions on this one huh?
Old Jun 19, 2009 | 12:36 PM
EBEATS's Avatar
nothin....
out of every one that has viewed my thread, no one has any opinion on my build.
Old Jun 19, 2009 | 12:54 PM
Gsr_Rob's Avatar
As far as the rod bolts yes 9mm ones are what you need in a gsr or type r. On the injectors I will let someone else chime in for that.
Old Jun 21, 2009 | 08:42 AM
redflaredcrx90's Avatar
start with 310cc it will give you a lil more room to grow on all motor
Old Jun 21, 2009 | 11:15 AM
94 ls-r's Avatar
Not sure what the ratio is as far as how much ethanol compared to how much gas is needed. 310cc is good for gas
Old Jun 21, 2009 | 02:43 PM
Lord Helmet's Avatar
Like what size?
Any Help??
if you want to run ethynol gas unmixed then you better change out the entire fuel system(fuel lines, etc...) because ethynol is very corrosive to begin with. btw 370 cc injectors would be a good start.
civic2slo
Aug 29, 2008 03:56 AM
GReddyjon
Nov 28, 2006 05:33 AM
jeremy.
199
Dec 23, 2004 03:45 PM
akhom
Oct 13, 2002 10:21 PM
akhom
Oct 13, 2002 07:58 PM
