----> how do i add 2 more injecotrs into my IC pipes and run a on/off switch on them.
as title states. must be custom cheap and done by me. how can i plum this in and how doees the injector work? just like a switch? can i just shoot on off or do i need to wire into the other to make pulsate etc.
most people ive talked to say to get an old VW's cold start injector and use that as it already has the banjo fitting. cant i jst use my obd0 injector????????
why would u wanna do that?
by the way... im being sarcastic. dont answer that question.
Would a fuel solenoid similar to the ones used on a wet nitrous setup work ?
I already posted links to this same question you asked over in the crx fourum. You need something like the sds extra injector controller. Dont be ghetto and try an use 1960 volwkswagon parts, just do your self a favor and buy the extra injector controller
Greddy and HKS make additional injector controllers...i believe they both make pieces to hold the injectors too...
but as a second thought...why not just use 4 larger injectors and a proper management system?
jasons
Dec 4, 2011 05:13 AM
JCracer723
Jun 25, 2006 06:03 PM
CimorelliCRX
May 17, 2003 10:24 PM
