need AC on civic 97 ex with swap wat do i need?
Old Jun 18, 2009 | 04:52 PM
GSREXMan's Avatar
Default need AC on civic 97 ex with swap wat do i need?
Hey guy i swaped my coupe with a GSR but now would like to have AC so do i need a special part to use my old ac compresor or can i use a GSRs or B16s conpressor?
N same goes for PS . Do i need anithing special to get power stering back?
Old Jun 18, 2009 | 05:08 PM
EK TUNER's Avatar
Default Re: need AC on civic 97 ex with swap wat do i need?
You need either a P54 AC bracket from the Del Sol VTEC, or a P7J AC bracket from a 1st gen CRV. Both brackets will allow your civic compressor to bolt up the B series block. As for power steering, you need to get a 98-01 Integra PS pump. Your 97 Civic PS line should bolt up to that pump. You can NOT use a 94-97 Integra PS pump, as the fittings are different.
Old Jun 19, 2009 | 12:40 PM
GSREXMan's Avatar
thank u for the help man
Old Jun 19, 2009 | 04:45 PM
Don Napier's Avatar
Import Alliance
I really think I have my stock civic p/s pump on my gsr swap. I will look when I get home.
RicerBoi16
Apr 22, 2019 06:03 PM
Johnnydc
Jan 15, 2011 10:18 PM
thumper64
Jan 30, 2009 10:40 AM
raidacaipo
12
Jul 11, 2008 06:57 PM
ssd
May 6, 2006 06:19 PM
