engine swap, d15b from d16z6, any real changes or straight swap?
HI there, I currently have the d16z6 motor and trans in my 1995 civic hatch, I am probably just going to swap a d15b jdm motor in it, I just want a reliable DD, with a little go without breaking my bank for sure, I dont need to go real fast. My questions are is it going to be a straight swap with harnesses and everything, or is there going to be any changes to be made with it?
Any help will be appreciated, Thanks!!
James
James
OK, that is a good thing, Im looking to do a direct swap, with out and major wiring changes, if any wiring changes, is this possible with this swap, or is there harness changes, Im going to do some research, I was just trying to get some input before i went to deep with it!! Thanks alot here!
Yeah you can do a swap without any wiring problems.
And since your civic is 95 it is pre-wired for vtec in the shock tower.
yes his car is prewired for vtec but thats because he had a z6 to start with. if he had a d15b7 then no it would not have that wiring in the cabin harness. only the 92 model year was pre-wired.
wait whats wrong with the z6, the JDM d15b is like the same engine, unless yur z6 has like a cracked block, or bent valves its not worth swapping it in
Its just got alot of miles on it, and I just bought the car, and just want something to do!! and just want to keep it small and simple.
Why don't you just rebuild the whole engine and put aftermarket parts into the rebuilt engine? You save time and money (I think)
Don't worry, the dude's on the right track! The D15B goes for $350-$500 depending where you go. If it's a low-mileage one, then it'll be worth it, and then he can rebuild his z6 if he wants to. And yes, only ALL 92s were pre-wired for VTEC. After that, only models that came with VTEC, were wired for it.
Thanks, the current motor has a good amount of miles, that is why im want to do the swap, in your opinion, would you do the swap, or rebuild the current one? also, would the transmission bolt right up, or would I have to get a d15b trans with the swap?thanks alot all of you!!
anyone done engine replacement or swap(doesnt matter which model) ? im planning on replacing my 350k KM engine for a 50k one.. its starting to mumble
direct swap if its the vtec 1.5
reuse your ecu
while its outta the car, freshen up the 1.5 with water pump, timing belt, upper and lower seals, the works. that way when its instyalled, it stays untouched for several thousand miels without any sort of issues
or it may be more worth while to fix up the Z6 and make it have a bit more grunt
reuse your ecu
Chip your ecu or get a P08. The P28 with z6 maps will run the motor but its not the right one for the setup.
I opened up both maps in Crome and the timing/fuel values are different.
Also, this link will help you:
http://www.d-series.org/forums/gener...-vtec-faq.html
Quick edit: Here is a thread on a guy swapping a D15B into his car with tons of pics.
http://d-series.org/forums/general-t...n-w-d15b7.html
Civics for life
Jun 21, 2013 08:42 AM
kris9
Feb 18, 2010 01:48 PM
