Do I need to bleed my brakes?
Old Jun 18, 2009 | 03:15 PM
D16SohcVtec's Avatar
Default Do I need to bleed my brakes?
Today I opened my hood to check my oil. And the windshield washer fluid line went behind the MC resevor tank and the whole MC brake fluid tank popped off and spelt brake fluid all over the engine bay. I wiped down the spill and hosed the area where the fluid spilled all over onto.
When I put the tank back onto the MC. There was still fluid in the MC to where it was still at the very top of the MC. I filled the tank back up and the brake pedal still is firm and the car still stops like normal.
Should I bleed the brakes?
Old Jun 18, 2009 | 03:30 PM
shogee's Avatar
Default Re: Do I need to bleed my brakes?
i think you should be good cause the mc didnt run dry or soundlike it has any air trapped in it
Old Jun 18, 2009 | 03:39 PM
EL Vap133's Avatar
So it still had a good amount of brake fluid in the reservoir left after it spilled? If yes then I wouldn't worry about it.
Old Jun 18, 2009 | 04:26 PM
batallic's Avatar
no u dont to bleed the brakes since there was still fluid inside the MC, and since u said the pedal feels firm yur fine
Old Jun 18, 2009 | 08:56 PM
Yeah it still had a good amount of fluid left. I'm going to drive it around the block a few times and see if any air bubbles got in there.
chowderhead
Sep 11, 2017 03:24 PM
telekineticz
10
Sep 10, 2008 03:57 PM
Steve
Oct 22, 2004 05:48 AM
CR_VtecCRX89
Apr 27, 2004 02:33 PM
Jordan_4WS
Jan 20, 2003 02:10 PM
