d15 block with d16 head
Old Jun 18, 2009 | 11:26 AM
hammergunner's Avatar
Default d15 block with d16 head
Ok i did a head swap on my d15 and got everything going fine and working great
but i got some really bad information last time i asked what would be needed to swap the heads
first of all, i was informed to use the water pump and timing belt tension pully
but i couldn't use any of those parts
all i used was the timing belt. i had to use all the other d15 parts.
and i was also told to change the oiler?
please anyone willing to help, don't help if you don't know what your talking about.
but thanks to everyone else who helped me with the right information.
Old Jun 18, 2009 | 11:39 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: d15 block with d16 head
dang. all you need is a d16 timing belt if you put a d16 head on it(taller) i did thiss to. on a d15. just the head and belt and the dizzy for some reason . the d15 just wasnt working with it. in the d15 block on the deck there is a plug dealy you have to take out that oils the head. and i used a msd vtec rpm activator dealy that is a dum idea. cuz i only had a p06 at the time. you shouldnt need anything else. throw on a y8 manifold while you at it though.
4doorcivic16
Apr 28, 2010 04:52 AM
sde780
Aug 20, 2009 05:29 PM
yrulkn@me
Jul 2, 2007 01:08 AM
Patrickchampagne2006
Mar 12, 2007 11:54 AM
Civiclized
Sep 28, 2006 08:46 AM
