Y8 manifold to a pre obd z6
(Searched no info) I fixing to plum a pm6 intake manifold for direct port n20, my questions is, would it be worth it to wait and use the y8 manifold because of better flo, if so what kinda problem's if any would I run into, or what little mods would have to be done for this to work. Setup is pre obd z6 in a crx. Thanks in advance.
i would wait for the y8 manifold. make sure to get one from a 5 speed as the automatics do not have an eavc and they have a different throttle body. you will also need the evap purge solenoid from a z6 manifold. just tap and drill one hole to mount it like it is on the z6.
Andy
Andy
