If you need OEM parts for your car, click here!
Flatirons Performance is actually part of the Flatirons Acura Dealership here in Boulder Colorado. So we have access to virtually any OEM factory part that you need whether you are just doing routine mantinence on your car, upgrading it, or doing a swap.
Here are some of the more common parts that we get requests for, but if you don't see what you are looking for, please send us a PM and we can track down what ever you need.
Thank you for looking.
J. Cooley
This is a new OEM Acura complete head for the 1998 - 2001 Integra TYPE-R, and comes with the factory backed 12 mo warranty. It will fit all 94 – 01 Integra blocks, and is a V-Tec head, so it is ideally for a V-Tec car.
This complete head comes with the following items:
- INTAKE CAM
- EXHAUST CAM
- ROCKER ARMS
- INTAKE VALVES
- EXHAUST VALVES
- VALVE SPRINGS
- LOST MOTION SENSORS
- ROCKER ORIFICES
- ROCKER ARM VALVE SHAFTS
- SEALING BOLTS AND WASHERS
- CAM PLUG AND CAM SEALS
The valves, springs and guides are all preassembled. Professional installation is recommended.
Click Here to order your Integra Type-R Complete Head Assembly - $1575.00
This kit includes all of the major gaskets needed to reseal the top end of your motor including but not limited to ...Head gasket, Intake manifold gasket, Exhaust manifold gasket, Valve cover gasket, Valve cover grommets, Spark plug tube seals, Cam plug, Distributor O Ring, Intake valve stem seals, exhaust valve stem seals, plus many of the other smaller o rings and gaskets.
There are 3 different kits available:
1997 - 2001 Type-R - $170.00
1994 - 2001 GSR - $182.00
1994 - 2001 LS/GS/RS - $145.99
Click Here to order your Integra Top End / Head Gasket Set for your 1994 - 2001 Integra
This is a brand new, genuine Acura head gasket for the 1994 - 2001 Type-R & GSR, and will fit all 94 - 01 Integras
Click Here to order your 1994 - 2001 Integra GSR & Type-R Head Gasket - $64.00
This is a brand new, genuine Acura set of valve stem seals for the 1992-2001 GSR and Type-R!
You will receive 8 intake stem seals and 8 exhaust stem seals, brand new and straight from Acura so you know they will fit and last as they should. Because we are a Acura dealer you will also have the Acura 12 Month Warranty!
Acura part #’s
12210-PZ1-004
12211-PZ1-004
Click Here to order your Integra GSR & Type-R Valve Stem Seals - $18.72
This is a brand new, genuine Acura timing belt for the 1994 - 2001 Integra GSR & TYPE-R ONLY !
Click Here to order your Integra GSR & Type R Timing Belt - $47.00
This is a brand new, OEM Timing Belt Tensioner for the 1990 - 2001 Integra, and will fit all models in that production range.
Click Here to order your Integra Timing Belt Tensioner - $64.15
This is a brand new genuine Acura water pump for the 1996-2001 Integra all except v-tec GSR!!
Click Here to order your 1996 - 2001 Non-VTEC Water Pump - $74.00
This is a brand new, genuine Acura water pump & gasket for the 1994 - 1995 Integra GSR models.
Click Here to order your 1994 - 1995 Integra GSR Water Pump - $100.46
This is a brand new, genuine Acura left front engine motor mount for all of the 1994 - 2001 Integras with the 5 speed transmission!
This mount fits at the left side of the engine compartment right to the drivers side of the a/c bracket. Failure of this mount can cause a shaking engine that feels like a irratic idle.
Click Here to order your new Integra Left Engine Damper - $38.95
Click Here to order your new Integra Right Engine Damper - $34.95
This is a brand new, genuine Acura Ignition coil for the 1992 - 2001 Integra [all models]
This is the real deal, straight from Acura so you know it will fit and last as it should. This comes with the factory backed 12 mo warranty.
Click Here to order your Integra Ignition Coil - $76.00
This is a brand new, genuine Acura Knock sensor for the 1992 - 2001 Integra GSR & TYPE-R!
Click Here to order your Integra GSR & Type-R Knock Sensor - $122.00
This is a brand new, genuine Acura rear engine mount bracket for all of the 1994 - 2001 Integra's with the 5 speed manual tranny!
Because this is the real deal straight from Acura you can be sure it will fit and last as it should! Perfect for that bracket that was damaged during engine/tranny swaps or it may even help with that engine upgrade?
Click Here to order your 1994 - 2001 Integra Rear Engine Mount Bracket - $56.00
This is a brand new, genuine Acura rear engine mount bracket for all of the 1990 - 1993 Integra's!
Click Here to order your 1990 - 1993 Integra Rear Engine Mount
If you are going to re-build your engine, why not use the best parts available?
This is a brand new OEM part, and it comes with the factory 12mo. or 12,000 mile warranty. The pump come with a new front main seal, new studs and relief valve.
This will fit all 94 - 01 Integra blocks.
[/size=4]Click Here to order your 1994 - 2001 Integra GSR & Type-R Oil Pump - $97.00[/size]
This is a brand new, genuine Acura oil pickup / strainer tube for the 1994-2001 Integra Type-R and GSR
Click Here to order your Integra GSR and Type-R Oil Pickup Tube - $38.00
This is a brand new, genuine Acura oil windage / baffle tray for all 1994 - 2001 Integra TYPE-R & GSR
Click Here to order your 1994 - 2001 GSR & Type-R Oil Pan Windage Tray - $37.30
As many of you Honda and Acura owners know it only takes one person to overtighten the drain bolt and strip out the threads. When this happens there is only one real fix, replace the oil pan. So if you need to replace your oil pan, why not replace with it with the best part available?
This it the Acura OEM Oil Pan & Gasketfrom the Type-R & GSR, and will fit all 94 - 01 Integras. It also has the factory backed 12 month waranty.
Click Here to order your 1994 - 2001 Integra GSR & Type-R Oil Pan - $160.00
This is the Throttle Cable Bracket from the 94 - 01 Integra GSR. Often times, this is helpful if you are doing an integra swap, or upgrading your non-VTEC head with a GSR head.
Click Here to order your 1994 - 2001 Integra GST Throttle Cable Bracket - $14.16
This is a brand new, genuine Acura Throttle cable for the 1994 - 2001 Integra GSR !
Click Here to order your 1994 - 2001 GSR Throttle Cable - $23.50
[ulr=http://www.flatironstuning.com/p-1525-acura-integra-type-r-throttle-cable.aspx][size=4]Click Here to order your Integre Type-R Throttle Cable - $24.95[size][/url]
This is a brand new, genuine Acura Throttle cable for the 1994 - 2001 Integra LS/GS/RS
Click Here to order your 1994 - 2001 Integra LS/RS/GS Throttle Cable - $22.15
Give your car the Type-R look with this Shift ****. The **** has red stitching and the shift pattern embossed on the top and is the Acura OEM part that came on the 97 - 2001 Integra Type-R.
Click Here to order your Integra Type-R Red Stiched Shift **** - $115.00
This is a set of 4 brand new, genuine Acura floor mats for the Integra Type-R. These will fit any 1994 - 2001 Integra 3 door model and the fronts will fit the 4 doors while rears will be a little off. These are the real deal, made to fit perfect and last for years.
Click Here to order the last few Brand New Type-R Floor Mats in the country! - $139.99
http://i62.photobucket.com/albums/h112/Scubynubie/Acura%20Hard%20Parts/Type-REmblems.jpg[/IMG]
Click Here to order your Integra Type-R Hood & Trunk Emblems. There are sold individially for $59.00, or as a pair for $109.00
This is a set of two brand new, genuine Acura "Integra Type-R" side stickers. These came on all 1997 - 2001 Type-R Integras. You get both a left and right side sticker.
There is a different sticker if you have a black car, so please specify the color of the car these are going on when you order.
Click Here to order your Integra Type-R Decal's - $49.00
J. Cooley
- INTAKE CAM
- EXHAUST CAM
- ROCKER ARMS
- INTAKE VALVES
- EXHAUST VALVES
- VALVE SPRINGS
- ROCKER ORIFICES
Acura part #’s
12210-PZ1-004
12211-PZ1-004
i dont really need any mechanical parts right now but i doo need a few oem 96 integra gsr parts.please let me know if you can get them and how much for everything shipped to 17070 please!
roof trim on both sides
3 piece front windshield trim with all of th eoem clips.
let me know if you can help me out!
J. Cooley
Do you sell a timing belt kit that contains all needed parts for a complete timing belt change? Kit includes like timing belt, water pump, tensioner, valve cover gaskets..etc?
If so, how much for the kit for a 91 Integra LS, stock B18a.
Bump! We've really been enjoying the response to this thread. Keep the requests coming guys, soon we're going to get a list of commonly ordered OEM parts with prices to post up.
i need 95 acura integra RS/LS/GS complete gasket kit
im in canada though
L9W1J2
how much for the kit + shipping total to that postalcode.
also interested in all three motor mounts for the same year.
lmk seperate price for all of those + shpping
thanks in advance
also let me know if u can get all the transmission seals, and input shaft bearing, and how much.
mines broken in my tranny and causing massive noise at idle
im in canada though
L9W1J2
thanks in advance
