Changing an oil pan, help.
Old Jun 18, 2009 | 09:07 AM
XvPreludevX's Avatar
New User
Default Changing an oil pan, help.
Alright, Precision Tune stripped my pan and denied all responsibility so rather than get pissed and go on a rampage I decided to just change the pan. I was wondering, does anyone know any kind of do it yourself guide for changing the pan in a 92 prelude and do I have to pull the engine?
Old Jun 18, 2009 | 09:11 AM
dagle's Avatar
Default Re: Changing an oil pan, help.
no, jack up the car.. drain the oil (or don't drain the oil if you want to make a mess)
unbolt the little bolts going all around, get a flathead and pry the pan off gently but firmly. by "stripped" your pan do you mean they stripped a bolt that is now stuck?
if so, get out your impact gun + cheap socket (kragen or something) and use 1 size lower, so if its a 10mm bolt use a 9. line it up and smash it with a hammer until it's snug on there, use the impact and zap it off. done!
Old Jun 18, 2009 | 09:41 AM
New User
no, they didn't strip the plug. They overtorqued it i'm assuming and stripped the hole, so now the plug won't tighten. I have it rednecked up with some red silicone making a gasket to hold the oil and plug in. But it still leaks so it's just a temporary fix to a long time problem.
Old Jun 18, 2009 | 09:44 AM
hardwhite2's Avatar
New User
well you could tap the hole one size bigger than it was and get a new bolt to fit. might be a cheaper fix
Old Jun 18, 2009 | 10:41 AM
New User
I'd rather just go ahead and replace it. I found a guy selling a pan for 10 bucks and it's in great shape.
Old Jun 18, 2009 | 05:27 PM
kornerk12's Avatar
could you helicoil a pan ? or timesert ?
Old Jun 18, 2009 | 08:50 PM
New User
probably
Old Jun 20, 2009 | 02:10 PM
meev182's Avatar
id just tap it, much easier. butttt i just did my pan cuz it was rotted out. you gotta drop the exhaust at the header collector and i unbolted some sort of crossmember?. its going from the rear to the front of the subframe. i also had to unbolt the clutch inspection cover to get the last couple bolts outs.
1drivinmofo
Mar 10, 2010 05:16 PM
gasha1
Jan 9, 2009 05:55 AM
CRXified
18
Oct 31, 2006 04:58 PM
92preludeSI
Mar 10, 2003 07:33 PM
