Talon TSI injectors for a SOHC BOOSTED
I got a quick question i just picked up a set of DSM 450cc injectors the guy gave me the ignition box, clips and injectors, the question is, he had it for an boosted LS in an eg, i looked at the wiring it looks different from my EJ8, is there anything i can splice? or can i just use my stock box for the 450cc injectors and use stock clips?? New motor = d16z6 old motor = d16y8
If your looking to run dsm 450cc injectors on an OBD1 car you can use the factory fuel injector clips if you notch out the groove on the dsm injector.. You could also use a resistor box or use 10 watt 10 ohm resistors. Please search there are several threads with info about this.
Here's one of the top of my head: http://www.homemadeturbo.com/tech_pr...ors/index.html
GL!
GL!
HARRY-DA
May 17, 2010 03:25 PM
