front end of an ek hatch shaking violently on the interstate
Old Jun 17, 2009 | 03:56 PM
liljohn850's Avatar
Icon6 front end of an ek hatch shaking violently on the interstate
So we're ridin down I-10 in my hatch and the front end was noticebly shaking like crazy. Its like, coasting down a hill or something is fine, but as soon as there's a load or any strain on the car it starts to shake hard core. Anyone got any ideas of what this could be? Txt me bc the internet on my phone is slow as hell. 8507581214. Thanks, any ideas are appreciated
Old Jun 17, 2009 | 04:09 PM
96DelSol's Avatar
Default Re: front end of an ek hatch shaking violently on the interstate
Ive had that on my del sol, it was my algnment, around 80mph it shook like crazy.
Adjusted my toe, and went to an alignment shop, problem solved.
Old Jun 17, 2009 | 04:24 PM
eros18's Avatar
just to be clear
a wheel balance would NOT fix the problem right away so when someone says "YOUR CAR IS SCREAMING FOR A WHEEL BALANCE" it doesn't mean the problem would be fixed.
even though they explain the wheel balance theory very specifically, it still wont fix the problem right away.
although you can check with wheel balance first then if the problem doesn't go away then do the alignment.
Old Jun 17, 2009 | 06:00 PM
soon2bdropped's Avatar
need more info could be anything,any rims on the car probably bent from pothole. inspect tirs could be anything, maybe even a slipped beltin one or more of the tires
Old Jun 17, 2009 | 06:12 PM
Former User's Avatar
Check your axles and motor mounts.
Old Jun 17, 2009 | 06:22 PM
delsolproblems's Avatar
I'll second that.
Old Jun 18, 2009 | 06:19 AM
liljohn850's Avatar
How can I tell by lookin at the axles if they're bad?
Old Jun 18, 2009 | 06:54 AM
Vindicator9000's Avatar
318 Curves, 11 miles
Third that.
Axles don't always visually go bad, but look around your CV boots and see if any of them are torn and leaking. If it's only vibrating under load, I'll almost bet on one of those rather than a wheel balance, bent rim, or broken suspension component.
Old Jun 18, 2009 | 07:06 AM
liljohn850's Avatar
yea it def only does it under load. and at certain speeds it goes away. should i go ahead and change em both or just the driver side one?
Old Jun 18, 2009 | 07:42 AM
Jimster480's Avatar
Fourth that.
If its only under acceleration it could easily be a Axle or motor mount.
Old Jun 18, 2009 | 08:11 AM
xjosfx's Avatar
I LIVE IN
if your axles arent ripped the other way to check if its bad is turn your wheel all the way one way and accellerate if you hear like a metal clicking then its the axle, try both ways, if one way makes that noise your gonna need to replace them. easy job.
Hatchman98
Paint and Body
Jul 31, 2007 12:34 PM
Timmycivic
Jul 16, 2007 07:33 AM
Tippyman
40
Jun 7, 2006 05:09 PM
dyases
Jun 10, 2004 08:56 PM
Mag00n
Aug 29, 2003 12:54 PM
