OT: Exhaust size for a 220WHP+ ITR motor - 2.5 or 3 inch?
Old Aug 20, 2002 | 08:09 PM
BlackGSR's Avatar
Default OT: Exhaust size for a 220WHP+ ITR motor - 2.5 or 3 inch?
Well, I'm now starting to work on my exhaust system. I currently have a JDM Mugen (2.5) header, Carsound cat, and Comptech exhaust.
I was originally going to purchase a custom 2.5 ID B-pipe and mate it directly to the header and purchase a 2.5 muffler (SMSP maybe).
I'm now thinking about going 3 inches on the exhaust. I know my car is not turboed - BUT - I'm shooting for 220WHP. MOST turbo kits (especially for the B16) put out around 220-240WHP. A 3" exhaust is a VERY worthly modification for FI.
Ultimately - would a 3 inch ID exhaust out perform a 2.5 ID exhaust? I really don't want to hear about low end bull$hit about less back pressure.
With a 2.0 Ltr motor - what ID exhaust would you guys get? 2.5 or 3?
Adam
Old Aug 20, 2002 | 08:13 PM
SMSP's Avatar
Default Re: OT: Exhaust size for a 220WHP+ ITR motor - 2.5 or 3 inch? (BlackGSR)
First off, the exhaust tubing is spec'd by OD. The sizes you see in ads, i.e 60mm or 2-1/2" are the OD.
For what you are looking at putting out in the way of power, a 2-1/2" system without any bottle necks should do just fine.
Old Aug 20, 2002 | 09:25 PM
ImportReview
Guest
Posts: n/a
Yeah 3 inch sucks for N/A, youll lose a grip of power. tested and tried .
Listen to Dave, 2.5 inch is good. Even crush bent, if its a good job is not that bad.
IB
Old Aug 21, 2002 | 11:45 AM
Drag R's Avatar
Default Re: OT: Exhaust size for a 220WHP+ ITR motor - 2.5 or 3 inch? (ImportReview)
what about a 2.5 piping w/ a turbo muffler, reason being , that the most universal mufflers, have a 60mm inlet, where as the turbos bave a 80mm, i know thats a lot but wouldn't it have better flow than one w/ a 60mm inlet???? Just curious.......
Old Aug 21, 2002 | 11:52 AM
sgT's Avatar
sgT
Default Re: OT: Exhaust size for a 220WHP+ ITR motor - 2.5 or 3 inch? (Top Fuel ITR)
my magnaflow has a 2.5" in and out
Old Aug 21, 2002 | 11:58 AM
eg6ajk's Avatar
70mm Kakimoto R exhaust....not 3" but not 2.5" either, well desing and well priced
rodrez.'s Avatar
Default Re: OT: Exhaust size for a 220WHP+ ITR motor - 2.5 or 3 inch? (sgT)
Using a 3-inch exhaust on N/A is almost like runnin open header, very little restriction, you will lose torque throughout, but you'll gain horsepower on the top end. My buddy is runnin a 3-inch exhaust (dropped a motor in his hatch, exhaust from old turbo set up was sitting in his garage, so we threw it on), and it's LOUD, even with a resonator, it's crazy loud! On the street, there's a definate torque loss, but on the top end, especially the freeway, it's gone
Old Aug 21, 2002 | 12:02 PM
sgT's Avatar
sgT
Default Re: OT: Exhaust size for a 220WHP+ ITR motor - 2.5 or 3 inch? (rodrez)
no. you dont lose torque
Old Aug 21, 2002 | 12:03 PM
MR. ARIZONA's Avatar
2.5
Old Aug 21, 2002 | 12:04 PM
TsunamiZC's Avatar
whats the stock size piping...is it 2.25
Old Aug 21, 2002 | 12:08 PM
Steve Kalesia's Avatar
I definately didn't lose torque. But then again, this is a little bigger than a 2.0l engine. 2.4l to be exact. Differences between runs are cam timing and I went from full 2.5 inch from the collector back to running an 18 inch dynomax bullet with a header turndown. Full length after tri y collector is approx 26 inches. The exhaust note is actually pretty quiet. Quiet enough to drive around town and not have any police take note yet. I thought it would be really loud, but the tri y collector also acts to quiet things down. I'd say go 3 inch if you are going full exhaust. You may need to add a 3 inch resonator too quiet things down a bit. I've heard a few NA cars with 3 inch exhausts and they tend to be rather loud. Much louder then my current set up.
Steve K.
Old Aug 21, 2002 | 12:26 PM
Black R's Avatar
25 Year Member
Default Re: OT: Exhaust size for a 220WHP+ ITR motor - 2.5 or 3 inch? (Steve Kalesia)
.....that doesn't look like a b-series plot.
Old Aug 21, 2002 | 12:27 PM
sgT's Avatar
sgT
Default Re: OT: Exhaust size for a 220WHP+ ITR motor - 2.5 or 3 inch? (Black R)
probably h22/23a
Old Aug 21, 2002 | 02:24 PM
Close it is actually a 2.4l out of a Dodge Minivan. I don't drive a Honda, it's a Neon. Hope you guys don't mind me lurking around your board, but I like to hang out at all the boards to learn from everyone. TTYL,
Steve K.
Old Aug 21, 2002 | 02:31 PM
sgT's Avatar
sgT
wierd, not too many non-honda motors make that much more hp than torque
Old Aug 21, 2002 | 07:32 PM
l's Avatar
l
if you own that 12 second minivan :thumbsup:
either way stick around.... non honda owners are welcome...
i always thought 3 inch mufflers were fine
but jeff would know more than i...
Old Aug 21, 2002 | 07:37 PM
Default Re: OT: Exhaust size for a 220WHP+ ITR motor - 2.5 or 3 inch? (IM ALL SHO)
Nope, 12 second Neon though
Steve K.
Old Aug 21, 2002 | 08:25 PM
EPGONZALEZ's Avatar
3 inch can work if properly executed...
speaking from expirience,
im talking big gains all over the map
but the 3 inch collector was only a small reason for the gains....
boxeocampeon
May 16, 2010 04:28 PM
JdmTypeRdc2
Oct 27, 2008 10:25 AM
teggy182
Mar 9, 2006 11:06 AM
S2KILLA
Aug 11, 2005 10:35 AM
R-gonaut
Nov 27, 2002 06:28 AM
