is it ok to remove the heat shield mounted on the floor above the cat?
Old Jun 17, 2009 | 11:15 AM
japspecjohn's Avatar
Default is it ok to remove the heat shield mounted on the floor above the cat?
its my last heat shield and I still have a rattle...thought it would be the one on the cat but it wasnt...its the one above the linkage mounted to the floor...will this cause any harm removing it?
thanks
Old Jun 17, 2009 | 11:42 AM
WDG_729_ITR's Avatar
Default Re: is it ok to remove the heat shield mounted on the floor above the cat?
I don't believe so.
Old Jun 17, 2009 | 11:47 AM
u dont believe it will cause any harm or you dont believe i should remove it?
thanks
Old Jun 17, 2009 | 01:34 PM
letsdrive's Avatar
take it off. nothing will happen.
Old Jun 17, 2009 | 05:26 PM
thanks
lol sorry...I meant I don't think anything will happen...it should be just fine.
Old Jun 17, 2009 | 06:34 PM
jhammond_82's Avatar
Reject Papi
it will not hurt anything, no. but you will notice that the shifter itself will become hotter in the hot days when you are running your car. a few months ago there were a few threads on this and thats the conclusion the op's were coming too. most of them only noticed the heat when the car wasn't in motion, because there is no air flow underneath the car.
Old Jun 18, 2009 | 04:43 AM
cool thanks
SOHC_MShue
Jun 14, 2003 09:23 AM
basmasta7
Nov 12, 2002 07:14 PM
B16CRX
Nov 12, 2002 05:52 PM
ekimmel
Apr 16, 2002 10:14 AM
Woody_geeser
Jun 28, 2001 11:37 AM
