Amber bulbs in cluster?
Old Jun 17, 2009 | 10:28 AM
a97b18b's Avatar
Default Amber bulbs in cluster?
I'm just trying to clarify if the jdm itr cluster and climate controls have just plain white bulbs like the usdm ones and that it uses a colored film in front of the bulbs that gives it the amber color? I need to replace some bulbs since some don't work unless I smack the dash and part of my cluster is dim. I can barely read the miles on the cluster.Thanks for your help guys.
Old Jun 17, 2009 | 11:06 AM
wrinkly's Avatar
Default Re: Amber bulbs in cluster?
i remember i had to change the bulbs on my jdm cluster and they were the regular plain white bulbs like the usdm cluster.
hmm i remember at the time a friend suggested replacing them with raybrig ones cuz they where brighter? iono how true that is tho
Old Jun 17, 2009 | 11:10 AM
racebum's Avatar
the actual gauge plastic is tinted to be amber. i found this out one day by placing a JDM ITR tach in a USDM GSR cluster. well, i had an amber tach and white cluster.
Old Jun 17, 2009 | 11:13 AM
CWTegRNo.160's Avatar
what type of bulb is needed? I got a blown bulb where the water temp it. Is it just me or is it a bit*h to get the cluster open? I tried to figure out how to fix my trip because the reset button doesn't work.
Old Jun 17, 2009 | 11:33 AM
SoTexDC2's Avatar
They're #194 just like the outer bulbs in the front turn signals.
Old Jun 17, 2009 | 01:01 PM
j3ng24's Avatar
keep it stock
Old Jun 17, 2009 | 07:03 PM
a97b18b's Avatar
Like i said in my original post, i have to smack my climate control to get the left four buttons that direct where you want the air flow to turn on. Do you guys think its possibly a loose bulb or if i were to replace them it would work fine??
Old Jun 17, 2009 | 07:51 PM
how many bulbs are in the cluster? If i have to replace one. i guess i should replace them all.
Old Jun 17, 2009 | 08:28 PM
a97b18b's Avatar
6-10, don't really remember.
Old Jun 18, 2009 | 07:37 AM
XslickwhitetegX's Avatar
well are you talking just of the 194 bulbs? there is only 3.. but the other bulbs there are i believe 22, so 25 all together. but the 15bulbs are ubler small and I think they you cant get them in store, only at acura dealership.
http://www.team-integra.net/sections...?ArticleID=315
I use Piaa extreme white in my edm cluster,they havent gone out in 2 years, but they arnt cheap, all because of the name..lol
hope that helps
CaliforniaDad
Nov 12, 2010 08:50 AM
BuBBa y0!
Jun 13, 2005 02:46 AM
Mario.
Jan 15, 2005 10:21 PM
itsJDMyo
14
Oct 19, 2003 05:22 PM
ReversE
Aug 19, 2002 05:02 PM
