ek manuel door window problem
Old Jun 16, 2009 | 09:28 PM
MurtazaDSM's Avatar
Default ek manuel door window problem
I have a 96 civic hatch with manuel windows. I went to put the window up today and it got stuck about 3 inches away from the top and the **** that puts the window up just keeps twisting and the window wont go up anymore. I have to pull the window up by force with my hand. How do I fix this?
Old Jun 16, 2009 | 09:30 PM
WickedKP's Avatar
Default Re: ek manuel door window problem
I belive the window regulator is gone.
time to replace it.
Old Jun 16, 2009 | 09:33 PM
likecatnipp's Avatar
i have everything you need to put power windows and 00 si panels plus seats in your car let me know
Old Jun 17, 2009 | 09:14 PM
MurtazaDSM's Avatar
I dont think its a regulaor I thought only the power windos have regulators
Old Jun 17, 2009 | 09:21 PM
96DelSol's Avatar
Did it go back down with the handle?
My dad had the same problem in his truck, he took the handle out and saw that the little teeth/design on it was scrathed off so it was slipping, check that.
Old Jun 17, 2009 | 09:27 PM
WickedKP's Avatar
there is a manual regulator and a power regulator either way there is a regulator.
it could be true the hand crank could be striped out.
someone told me u can get a handle crank at autozone or kragen.
that just what happend to me.
so i went factory power everything on my ek now.
Old Jun 17, 2009 | 10:02 PM
ifIexplode's Avatar
Giving that its a 6th GEN civic, Either the window has popped off its tracks or the regulator is bent,You may have stripped the teeth on the regulator, If the window crank handle was stripped it wouldnt put the window up at all, Id take the door panel off and inspect the window tracks and regulator. Get some silicone lube and spray down the rubber tracks, Even sometimes the exterior part of the window track gets pulled into the groove. Honda really Sh*t the bed on the regulator design, VW ones are cables with little pulley which is a pretty slick idea.
4Dinsaneb16
Mar 20, 2007 01:30 PM
Jonathan_ED3
May 9, 2005 11:42 AM
holeeray
Mar 6, 2005 01:36 PM
.jacob
11
Mar 3, 2003 05:25 AM
lp3kr
15
Apr 1, 2002 11:16 PM
