Will a 14" stock civic steel rims DX fit rear disk setup.
Old Jun 16, 2009 | 08:53 PM
WickedKP's Avatar
Default Will a 14" stock civic steel rims DX fit rear disk setup.
Hello
I was planning to do a rear disk swap on a 1998 civic hatch DX.
I might be from a integra or 99-00 Civic SI
and I was wondering if a stock steel rim 14" will clear the rear disk setup.
Thanx
Old Jun 16, 2009 | 09:51 PM
runwitme's Avatar
Default Re: Will a 14" stock civic steel rims DX fit rear disk setup.
i dont see why not .. i got integra rear disk brake on my 96 HB .. stock 14" on it too for now .. =D
Old Jun 16, 2009 | 10:03 PM
WickedKP's Avatar
thanx 4 the info.
I need new brakes for the rear so i rather do the swap to disk.
and now knowing that the 14" will fit save me some money from buying rims & tires.
Old Jun 16, 2009 | 10:28 PM
eg grom's Avatar
Yeah, I'm not sure about the ek models, but I did a rear disc conversion on my eg and I'm still rockin out the steelies on mine.
Old Jun 17, 2009 | 01:35 PM
94EG8's Avatar
Seagull Management
As far as the rears go you can run 13s. If you're using civic EX/Si or Integra front brakes you'll need at least 14s on the front.
Old Jun 17, 2009 | 07:29 PM
WickedKP's Avatar
So ex/si front disk will fit with 14" rims. wow that just opened up some more project.
thanx so much for the info people.
Old Jun 17, 2009 | 07:43 PM
yoontim23's Avatar
You will clear 14" rims in the rear with 00 si disc, but if you got 00 si brake setup on the front then 14's wont clear.
Old Jun 17, 2009 | 07:53 PM
hOnda_hiEn's Avatar
so youre sayin 14s wont fit on the front of an si..??
Old Jun 17, 2009 | 07:58 PM
hmtcrxsir's Avatar
they will fit. they just wont fit anything lower than 14 inch rims. i got first hand experience on this.
Old Jun 17, 2009 | 08:29 PM
hOnda_hiEn's Avatar
Old Jun 17, 2009 | 08:30 PM
hOnda_hiEn's Avatar
Originally Posted by hmtcrxsir
they will fit. they just wont fit anything lower than 13 inch rims. i got first hand experience on this.
Old Jun 17, 2009 | 09:17 PM
WickedKP's Avatar
OK i'm really confused on the front brakes. so will a 14" fit in the front??
I checked online and i didn't see any difference in part #
I compaired the following models from rotor, caliper assembly, knuckle, ect..
2000 civic SI front brake m/t
1999 civic SI front brake m/t
1999 civic EX front brake m/t or auto non abs
1998 civic EX front brake m/t or auto non abs
so ex or si model auto or manual 1998-2000 are same front brake assembly.
correct me if i'm wrong.
Old Jun 17, 2009 | 09:23 PM
90_EX_Civic's Avatar
dude, you'll be fine running 14" rims all around.
it will clear
Old Jun 18, 2009 | 05:00 AM
94EG8's Avatar
Seagull Management
14" steelies will clear in the front, a lot of base model RS Integras and all EX civics came with 14" steel wheels. At least some 14" Alloys (including the HX) don't clear without using wheel spacers or grinding down the front calipers.
andyboy
12
Apr 23, 2010 10:14 PM
4gen4drcivic
Dec 29, 2008 07:13 PM
streetracerjoey210
10
Jul 20, 2006 09:16 PM
Se-rv-Tak
Dec 20, 2003 08:51 AM
ek6-crvtec
Aug 19, 2002 03:50 PM
