NEED help vtec isnt working
Old Jun 16, 2009 | 06:55 PM
vLad11591's Avatar
Default NEED help vtec isnt working
I havent checked the solenoid.. But i know that could be one possible problems, my question is if i have a gsr vtec solenoid on a b16 engine would that cause problems? I would like to know because my buddy said that you could do that and he found a great deal on one if it is the solenoid. It sounds pretty bogus to me
Also if my speedo likes to go crazy sometimes i shuold check the VSS right? It just randomly goes from like 0-120 sometimes idk why
Old Jun 16, 2009 | 07:25 PM
vLad11591's Avatar
Default Re: NEED help vtec isnt working
buimp
Old Jun 16, 2009 | 07:30 PM
slow96lude's Avatar
yea the VSS is the culpret there. and the v tec solenoid is fine. how do you know your not hitting vtec. do you have any CEL reguards to vtec
Old Jun 16, 2009 | 08:10 PM
boostB4beauty's Avatar
check knock sensor wires, or even the knock sensor itself.
Old Jun 17, 2009 | 02:02 PM
vLad11591's Avatar
i dont hear it kick in at all. it just doesnt even sound like anything anymore.. thats how i can tell.. no theres no cel. but i know for a fact theres no vtec it usually sounds very loud and i dont hear anything but the rpms raising lol..
Is there any way i can use a gsr solenoid on the b16? or i NEED a b16 solenoid on it
Old Jun 17, 2009 | 04:54 PM
vLad11591's Avatar
bump
Old Jun 17, 2009 | 08:18 PM
vLad11591's Avatar
tttt need help!!!
Old Jun 17, 2009 | 08:23 PM
hOnda_hiEn's Avatar
hmm.. a b16 solenoid is fine on a gsr.. speeedo going crazy.. yea check your vss.. vss can affect vtec..
Old Jun 17, 2009 | 08:24 PM
hOnda_hiEn's Avatar
i meant a gsr solenoid on a b16 is fine..
Old Jun 17, 2009 | 08:35 PM
vLad11591's Avatar
well im getting a jdm b16 solenoid with the VSS for 70 so if that doesnt solve my problem idk what will... Also my idle seems to be a little weird sometimes. it sounds like it just wants to die sometimes, should i get a new tps? or just try cleaning out the IACV
Old Jun 17, 2009 | 08:52 PM
hOnda_hiEn's Avatar
try the iacv.. take it off and take some carb cleaner to it. clean the screen too..
Old Jun 18, 2009 | 09:48 AM
vLad11591's Avatar
thanks for all the help.. im going to try cleaning out the iacv and the fitv when its sunny out but im deff gonna have to get a new solenoid
Old Jun 18, 2009 | 05:56 PM
vLad11591's Avatar
well the idles gone, and i cleaned the vtec solenoid and everytthing... Turns out im leaking/burning oil. I check my dipstick as a last resort and theres nothing, and i changed it about a month ago.. Doesn anyone know where a common oil leak would be? I dont think i would be burning oil because its a relativley new engine, and it doesnt smoke, or feel that its less power. If it is an oil leak, it wont be too expensive right? Im also going to run a compression test just to make sure im not burning oil or anything like that.. If its low in any cylinders im F'ed for life
Old Jun 25, 2009 | 05:31 PM
vLad11591's Avatar
ok i gotta change the drain plug.. but i cant hit vtec still because my speedo goes crazy.. i checked the VSS and its not loose or anything so idk wat to do
Laojoeturbo
34
Jun 24, 2009 08:47 AM
JsSIR
Jul 14, 2008 08:14 PM
sheepey
Jul 29, 2004 04:21 AM
pr3crx
Feb 5, 2004 10:04 AM
r7
12
Jun 13, 2002 10:21 AM
