Removcing the shock tower cover
Probably not the right name for it but anyways, my upper ball joint/camber kit is hitting this cover in the picture below. It seems to only be fasten with some hardened glue and looks as if I could cut away the glue and pull it off. I remember seeing a picture of it done, but I wanted some feedback on this. I found a pic of one cut out to show you. But I'd like to remove the whole thing if possible.
Not sure what kind of feedback you are looking for. Remove it if you want, it should be pretty easy. Of course the bay will get dirty, but then your camber kit will clear.
slowpokesi
Feb 11, 2003 09:12 AM
