stock b20 what should i do?
Old Jun 16, 2009 | 10:34 AM
chrisfromsrq's Avatar
Default stock b20 what should i do?
i have a stock b20 except for usdm GSR tranny
ITR shift Linkage
ACT stage 3 clutch 6 puck sprung
Fuel Regulator
Fuel Gauge
Golden Eagle PRO SERIES fuel rail
what do you think i should do next
Old Jun 16, 2009 | 10:35 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: stock b20 what should i do?
turbo
Old Jun 16, 2009 | 10:37 AM
with stock internals? how much boost should i run and what kit should i get? this is my dd so i dont wnat to blow the motor.
egb20v's Avatar
what are you trying to acheive with your car? what do you use it for?
Old Jun 16, 2009 | 10:38 AM
its my dd
Old Jun 16, 2009 | 10:41 AM
I'm not Rick!
alot of people are getting 400hp easy on stock internals without a vtec head. dont be scared. good tune. quality parts. you can get alot of power out of your setup. do 10lbs youd be happy but youd get addicted
Old Jun 16, 2009 | 10:44 AM
what kinda kit do you think i should go for?
Old Jun 16, 2009 | 10:46 AM
egb20v's Avatar
honestly i wuldnt turbo a stk internal b20, they are very prone to cracking cylinder walls because of the sleeve design.... if your looking for a cheap way to get a few hp i wuld recomend slapping on a vtec head or maybe just get a good set of cams
Old Jun 16, 2009 | 10:48 AM
ive been thinkin about puttin a turbo on it for a while i just dont know if i should. at most id run 10lbs becuase i wouldnt want to blow it. i have to drive to school an work n stuff.
Old Jun 16, 2009 | 10:53 AM
I'm not Rick!
many many people turbo stock b20 and with no problem and make lots of power. when you get addicted turn it up over 15lbs and get nutss then youll want xtra motor laying around.
https://honda-tech.com/forums/showth...tock+b20+turbo
Old Jun 16, 2009 | 10:58 AM
egb20v's Avatar
yes i'm sure there are many ppl that do it and can get away with it....... but they do crack sleeves...and they have week little rod bolts same as d series stock b20 is NOT a good platform for turbo.... but it is not my motor or my money so ****IN BOOST THAT **** on 15psi and enjoy (=
Old Jun 16, 2009 | 11:00 AM
haha well im not in a rush to do anything. if i got some nice headers would it make any difference?
Old Jun 16, 2009 | 11:01 AM
i want to keep the ac on the car though because its to hot durring the summer down in florida
Old Jun 16, 2009 | 11:03 AM
egb20v's Avatar
its not gonna be like BAM!!!! HOLY $#!+ THIS HEADER MAKES MY CAR FASTbut it will help yes maybe 6-7hp
Old Jun 16, 2009 | 11:05 AM
egb20v's Avatar
and dont just get a cheap header and expect it to do amzimg things... you have a 2.0 you need a header for a 2.0
Old Jun 16, 2009 | 11:07 AM
egb20v's Avatar
ITR shift Linkage
Fuel Regulator
Fuel Gauge
B20B or B20Z????
any website i should check out for parts and accessories an stuff like that.
Old Jun 16, 2009 | 11:08 AM
jdm b20b
Old Jun 16, 2009 | 11:20 AM
egb20v's Avatar
i dont know of any specific sites to go to.... search on forums and see what ppl are using and what results they are getting, thats where you will learn the most..... and just go from there! i personaly culdnt tell you what turbo kit i wuld recomend because i have never been a fan of turbo's
Old Jun 16, 2009 | 11:23 AM
true what do you have done to your b20?
Old Jun 16, 2009 | 11:28 AM
Matt93eg's Avatar
Nice hood props man. Looks pretty much just like my engine bay..cept I have the 1.8L LS.
Old Jun 16, 2009 | 12:48 PM
I'm not Rick!
egb20v...hes asking you
Old Jun 16, 2009 | 01:43 PM
egb20v's Avatar
i saved for a long time and am broke still because of my build lol
00 b20z2 block honed and decked eagle rods weisco pistons B16A2 head with s2s2 cams and complete valve train skunk2 manifold and bisimoto header(temporary) and b16 trans.... this setup made 213 hp and 178ftlbs
Old Jun 16, 2009 | 01:45 PM
how much did all that cost?
Old Jun 16, 2009 | 01:50 PM
egb20v's Avatar
By the time it was all said and done with labor and everything i ended up spending like 6 grand that included buying the crv shortblock and b16 head... tranny came of an old car i had b4
