BrewSpeed fabrication/parts thread
Old Jun 15, 2009 | 04:10 AM
Brad Campbell's Avatar
Default BrewSpeed fabrication/parts thread
I am going to start my own thread like others on here so I don't keep clogging up the works every time I do something new. I'm going to post my other pictures up here eventually as I need to move around some items in my website. Thanks for the space as usual!
-Brad
Old Jun 15, 2009 | 04:15 AM
Default Toyota MR2 intake manifold flange
Just a quick laser-cut finish machined 3/8" aluminum weld flange for some MR2 intercooler plumbing.
Old Jun 15, 2009 | 04:53 AM
Default Eagle Talon 3.5" downpipe
I had trouble finding 3.5 inch u bends in the quality of material and bend radius I wanted, so I decided to do some laser-cut pie slices. I am really happy with the way this turned out. This saves an incredible amount of time and effort and allows me to completely customize the bend radius. If I wanted to get tricky I could have even laser-cut the holes for the O2 sensor/EGT probe bungs or a port to recirculate the wastegate dump.
Old Jun 15, 2009 | 06:42 AM
per4mance's Avatar
Default Re: BrewSpeed fabrication/parts thread
thats pretty awesome. What kind of laser cut machine do you use?
Old Jun 15, 2009 | 07:14 AM
m R g S r's Avatar
How do pie cuts save time? It must have taken forever to weld that many pie cuts around 3.5" tube.
But your work is top notch, keep up the good work!
Old Jun 15, 2009 | 07:21 AM
Ha! I meant compared to cutting the slices by hand Welding it all up was painfully time consuming. Thanks for the complement.
Laser is by Trumpf.
Old Jun 15, 2009 | 07:58 AM
weiRtech's Avatar
OG Fabricator
i need collectors! what file format do you want them in? is iges ok? i'm surprised you aren't cutting them all day already.
Old Jun 15, 2009 | 09:07 AM
T76U13ALT's Avatar
So are you going sell kits of these pie cuts on your website? How many degrees are they cut to?
Old Jun 15, 2009 | 09:13 AM
Pretty much all of my parts are made to order. These were 15-degree pieces.
Old Jun 15, 2009 | 09:39 AM
AFI Turbo's Avatar
Looks great Brad!
Will be calling you later
Old Jun 15, 2009 | 01:36 PM
914Racer's Avatar
The parts look great, but why not save yourself lots of time and just order 3in donuts and cut the exact sections you need from them. You can get up to a 360 deg radius with them.
Old Jun 15, 2009 | 02:34 PM
JDM KID 510's Avatar
Nice.
Old Jun 16, 2009 | 04:29 AM
I ordered a single U bend, but sent it back as I was unhappy with the quality. It is 3.5" however which made it a little more difficult. I also wanted to make a smaller bend radius... so this was the obvious answer for me.
Old Jun 16, 2009 | 04:33 AM
Default AWD conversion hub/caliper brackets
Old Jun 16, 2009 | 04:35 AM
Default 6-1 T4 Collector with integral gate port
Old Jun 16, 2009 | 04:53 AM
weiRtech's Avatar
OG Fabricator
please tell me you are making a couple spares and throwing them on the shelf as you go.
Old Jun 16, 2009 | 08:13 AM
Default baby t25 3-1 and 4-1's
It depends on what it is. It's almost easier to do it to order then have spares all over the place. I'm trying to keep common setups in stock, but everyone seems to want something a little different.
Old Jun 16, 2009 | 08:26 AM
914Racer's Avatar
The donuts I have used come in a 3in radius for a 3in tube.
HTML Code:
http://secure.chassisshop.com/partpic/400/300/assets/catalog/parts/ProWerks/pn_C76569SS/C76-569-SS_1.jpg
914Racer's Avatar
Well that didn't work. Here is the link to the picture:
http://secure.chassisshop.com/partpi...6-569-SS_1.jpg
Old Jun 16, 2009 | 09:41 AM
Yeah... the chassis shop has some nice pro-werks stuff. The slices I made were probably close to a 2" center-line radius though, and the 3.5" donuts were only in 14 gauge, and were a little rich for my blood. Regardless thanks for the link
Old Jun 16, 2009 | 01:00 PM
-RedneckDave-'s Avatar
Working
Be careful that you don't turn this into a commercial thread. That is a no-no since you are not a forum sponsor. By commercial thread, I mean don't post parts in here that you are drying to drum up business on.
Old Jun 16, 2009 | 02:53 PM
srmofo's Avatar
^^ I think he is just trying to show off the precision of his fancy new laser cutter. Although you might want to show more stuff welded together so mods dont get that impression and delete your thread.
Old Jun 16, 2009 | 04:13 PM
91jdmhatchback's Avatar
well **** you can look at any thread and say there may be some sort of advertising being done. everyone stop posting stuff in the fab section....
Old Jun 16, 2009 | 05:18 PM
under_boost's Avatar
brad is the real deal. i looked for someone to make me some custom parts, and he jumped in on the opportunity.
Old Jun 16, 2009 | 07:36 PM
srmofo's Avatar
does the laser cut the bevel in the pipes for you or do you still have to do it before welding? or can it be set up to do that?
