Suspension & Brakes Theory, alignment, spring rates....
need help guys
Old Jun 14, 2009 | 05:57 PM
sohcsi's Avatar
New User
Default need help guys
what is the different in a eg strut fork and a da fork? pic if u have some.really need help with this!
Old Jun 15, 2009 | 12:05 PM
rick_rabies's Avatar
I'm not Rick!
Default Re: need help guys
no dif
Old Jun 15, 2009 | 12:42 PM
JNocon's Avatar
If you are talking about the design, it's basically the same, left and right. But, if you put an EG shock on a DC fork(no sure about DA forks), the EG shock O.D. is about 2mm bigger than the DC fork I.D.
Old Jun 15, 2009 | 01:06 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Incorrect, 92-95 Civic and 94-01 Integras use the exact same part number for the front shock forks.
DA forks are different, but I do not know what the exact difference is.
Old Jun 15, 2009 | 09:06 PM
sohcsi's Avatar
New User
thanks guys i did find the difference...the da forks are smaller and the eg struts well not fit.....and i fixed it
Old Jun 16, 2009 | 11:56 AM
JNocon's Avatar
We are referring to where the shock fits, the shape of it is the same, but where the shock fit is different in I.D. Why don't you try fitting a DC fork with an EG shock. Here's the pic measurement of a DC fork, imma take my EG fork out this weekend and I'll measure it and you'll see the difference by those two. The DC shock is smaller in O.D., but if you fit that shock on an EG fork, there's some clearance involve, even though you tighten the 14mm locking bolt. Do your "field research", homeboy!!!
Old Jun 16, 2009 | 01:01 PM
Community Builder
I have never had a 92-95 Civic so I can't very well do "field research". I'm just going by the factory Honda part numbers, which are the same for both 92-95 Civic and 94-01 Integra shock forks. I can't really see how different parts could be sold with the same part number.
dunkXdrift831
Sep 27, 2009 06:54 PM
Civilized81
Apr 28, 2009 09:10 AM
petwhookie
Apr 24, 2009 05:20 AM
94LSmanual
Feb 3, 2007 10:29 PM
JuanK20
Mar 31, 2006 03:52 PM
