What is this that's making noises? **PICS**
When I first start the car, it will make a long & continuous noise for about 15-20 seconds and then it'll stop. Does this mean that it's going bad or am I just low on fluid?
Would a unit from 98+ model year work on my 1995 LS Special Edition model?
What fluid does it take?
It Wouldn't be low on fluid unless I have a leak somewhere?
UPDATE: Nevermind, I just bleed the air out & fill it up with fresh brake fluid and now it's a lot better. WOOT!
The high pressure reservoir can leak past a valve back to the reservoir when the car is off. The buzzing is it recharging the pressure when you start the car. You are most likely not low on fluid or else the buzzing would continue and the ABS light would illuminate. This is common with these units.
A 98-01 (97 ITR as well) ABS unit is not compatible without extensive electronic and plumbing work.
