Closing my shop...MASSIVE Parts Sale..new and used turbo,nitrous,susp,wheels,MORE
Old Jun 13, 2009 | 01:50 PM
RC000E's Avatar
Default Closing my shop...MASSIVE Parts Sale..new and used turbo,nitrous,susp,wheels,MORE
Heading out of the scene and shutting down the shop, so I'm liquidating everything I have. Starting off, I'm going to clear out what I don't need/use. I have a pic taken of every thing for sale, but posting them all in here would suck. If you want a pic email me. Please don't ask for a pic if you aren't in the position to buy though...I don't want to be sending tons of pics wasting my time.
Forced Induction stuff
Turbonetics Super 60, .48ar hotside, T3 flanged. Coupe ran 11.80 full interior on a built B16 with it. Slight shaft play....ideal 180-350hp turbo with quick spool.....SOLD
HFmanifold-14b adapter for budget Dseries turbo setup...35.00
4" Stainless flex section...55.00
(2) 2.5" stainless flex sections...40/pc
Ramhorn Bseries turbo mani....SOLD
Goathead polished (ebay style) Bseries turbo mani...70.00
(3) Resistor boxes...20/pc
GM 3 bar with plug...40.00
GM 3 bar w/o plug...20.00
3.5 Bar AEM with plug and harness never used...85.00
30/30 Autometer Boost Gauge...needs boost line (can buy at pep boys)...30.00
30/30 Off brand boost gauge brand new...30.00
315 injectors...50.00
(2 sets) 450cc injectors...one blue top, one black top from 2nd gen...75.00/each set
DSM sidemount intercooler...30.00
Dseries COMPLETE turbo setup...includes piping, manifold with 14b style flange, DSM 1g BOV, Dump tube, DP, Johnny Racecar intercooloer, 3ply couplers, Tbolts, stealthmode oil line kit, more...475.00
Main Line Nitrous (Nitrous Express brand) single nozzle fogger kit. Complete kit for any EFI equipped vehicle. Includes everything but a simple toggle arming switch...SOLD
Suspension, brakes, Wheels, and Tires
Civic EX style 92-95 type hubcaps 7.00/pc
Complete set 17"x7" 4x100 Kosei K1's in white...2 good tires, one repairable tire (punctured but good tread), one with no tire....290.00
(2) 205/40/16 tires with good tread...don't match though...20/pc
(4) Full set 205/55/15's...two with 25%...two with 35%...will get you by if you need them....75.00 full set
Calipers, knuckles and rotors off of DelSol. Not the 10.1" EX size. Standard 9.6"...50.00
Front Sway bar with LCA's from 4dr EX for 92-95 Civic that came without it...nice cheap handling upgrade..65.00
LS Integra front and rear swaybars with appropriate LCA's for use on EF chassis. Has Energy Suspension bushings installed...85.00
Exterior Parts
Complete 92-95 Front end cut..NO BODY PANELS OR DRIVETRAIN (cut at a-pillars)
Complete 88-91 Civic hatch front end cut (cut at a pillars)....both good for mockup of custom mounts, setups, suspension parts, etc....85 a piece
Benen anodized black tow hook....40.00
(2 sets) EF hatch corner lenses....17/pc
Complete set Civic 4dr taillights for 92-95...clean...50.00
DelSol Carbon fiber hood...descent shape...not perfect...will work. 100.00
Drivetrain components and cooling system
92-00 Dseries Civic rad...nice condition...45.00
Integra DA rad...can be used on Bseries swapped Civic...full width size...SOLD
Z6 heads (have two complete with no vtec sol.)....45.00...add full port and polish for 250.00..have pics and examples of work
Y8 head...clean....35.00...same porting offer above
Z6 valve cover...25.00
LS valve cover...older style...25.00
SOHC Dseries adjustable cam gear...45.00
Machine Lightened stock Bseries flywheel...6 lb reduction...clean and structure retained...40.00
Complete header wrap kit with clamps BNIB....55.00
Cheap intake setup with filter for civic....SOLD
Complete 5 speed conversion with pass frame rail mount, slave, master cyl, hard lines, pedal assem, shift linkage, shifter, etc. All you need! 110.00
Various distributors...LS OBD1, OBD2, D16z6 with no plug, Pre-OBD LS, etc. Tell me what you need...all work..some need plugs wired on that's it....35.00/pc
Various intake mani's for D and B...PreOBD and OBD1...(b16's, LS, D16Y8, D16Z6...have one or more of all)...good for ITB projects...30.00/pc
S20 (z6) hydro tranny....100.00
P29 pistons for high compression sohc build...will make 11:1+ in z6 and Y8 combinations...true ratio depends on head, headgasket, and other variables..BNIB with rings...100.00
3" K&N filter freshly cleaned and oiled...velocity stack inside...good for all/motor street...35.00
Civic 4dr Midsection for exhaust...nice...50.00
Interior
DelSol Si Vtec cluster with 8200rpm redline...clean!...95.00
Integra rear seat delete (94-01)...fits nice...100.00
Corbeau Seat rail for EF...50.00
5pt RCI Racing harnesses...not ricer harnesses...approved by various sanctioning bodies...good for a track car....80/pc...or 150 for both
Personal Grinta steering wheel..never used. Blue suede..NICE....249.00 new...BNIB...150.00
CRX center console...40.00
EF hatch center console....35.00
ECU's
Will chip or socket any ecu below (except for OBD2's) and include SST rewriteable chip with basemap for an additional 50.00
Will chip YOUR ecu for 65.00 including chip and base
Trying to liquidate chipping kits and supplies as well which is why I am offering the stuff above
OBD1
P72 virgin...110.00
P28 virgin...110.00
P06 virgin...60.00
P05 virgin...40.00
P28 virgin...110.00
OBD2
P75 OBD2a and one OBD2B....75.00/pc
Pre-OBD
(2) PR4's....70.00/pc
MISC
Jeep steelies for wrangler or cherokee...full set...45.00
DSM 1g full pillar dual pod...BNIB...40.00
Grand National intercooler...35.00
DSM ported O2 housings...1g...instant power gain and reduction in spool time...50.00
Call 412-969-6041 or pm....DO NOT POST HERE...I HARDLY CHECK THE THREADS. PM ME!!!!
Stuff is already priced low...will accept reasonable offers, but crackhead offers will be passed on. Stuff must go! Pics available of all like I said.
Old Jun 13, 2009 | 03:32 PM
Honda_San's Avatar
Default Re: Closing my shop...MASSIVE Parts Sale..new and used turbo,nitrous,susp,wheels,MORE
bump for great prices! hopefully that turbo will hang around for a minute till i can afford it...ticket=uhg
Old Jun 13, 2009 | 05:12 PM
Kr4nG's Avatar
Can u send me a pic of the turbo? I'm very interested. Thanks
Old Jun 13, 2009 | 09:06 PM
boostdc211's Avatar
pics of turbo and of the 205/55 /15 tires and also bseries ramhorn mani
Old Jun 13, 2009 | 09:25 PM
gsreg94's Avatar
interested in b series mani pm me cash in hand
Navy_CRX's Avatar
Pick of lca
Old Jun 13, 2009 | 09:40 PM
b16ajdmrex's Avatar
PICS and ill buy a whole lot of stuff please!
Old Jun 14, 2009 | 09:45 PM
croninc's Avatar
pics of the boost gauges please, pm if that is easier. Thanks!
Old Jun 15, 2009 | 12:01 PM
RC000E's Avatar
BUMP
Old Jun 15, 2009 | 02:16 PM
pumpkinz6's Avatar
pm'd email is hic7877@cup.edu
Old Jun 16, 2009 | 07:37 PM
tonykdee's Avatar
you got pm!
highvelcty
Oct 9, 2005 09:31 PM
