Built SOHC Turbo Partout!
Hi all, parting out the fully built hatch project. Looking to get some money to buy a bike and some new machining equipment. All prices are fair but im open to offers. Need lots of money to pay off bills and use the rest for down payment.
More current pics will be up tonight. The turbo setup has 500 miles on it. The bottom end has 2500 miles on it.
Bottom End: !SOLD!
D16Z6 Block Std Bore and Notched
YCP Vitaras arrow facing trans the proper way
Hastings Rings
FJ Distributors Custom Length I-Beams
ACL Race Bearings all plastigauged and wore in correctly
KMS Engine Development High Pressure Oil Pump
All Brand New Gaskets
New OEM Water Pump
Y7 Crank Pulley
OEM Resurfaced Flywheel
ARP Flywheel Bolts
ARP Pressure Plate Bolts
Competition Clutch Stage 5 Pressure Plate and 1420 4 Puck Sprung Clutch Disk
ARP Headstuds torqued to 75 ft/lbs with 10w30 Oil
New OEM Timing Belt
New OEM Timing Belt Tensioner
Compression Test was 185 - 185 - 185 - 185
Head: !SOLD!
D16Z6 Casting
Stage 4 Porting done by PerformancePorting.com from Loveland Colorado #340
Skunk2 Forged Nitride Coated Stainless 0.5mm Oversized Valves
Blox Racing Turbo Valve Springs
Blox Racing Titanium Retainers
All New Gaskets and Seals
2 valve cover bolts are stripped and need a helicoil
Vtec Solenoid was rebuilt, cleaned and new seals painted like new
Stock Z6 Intake Mani
Stock Fuel Rail
Stock FPR
Stock Injectors
Rebuilt fresh distributor
NGK BKR7-11 plugs
Hondata intake manifold gasket
OEM Headgasket (if buying the complete long block)
Stock Cam (Can include new ZEX 59300 NIB for cash)
Stock Cam Gear (Can include an adjustable for cash)
PPG Army Green Valve Cover
Blox 70mm Throttlebody !SOLD!
Omni/Hondata 4 Bar Map !SOLD!
Inline4.com 70mm Heat Shield Throttlebody Gasket !SOLD!
Drivetrain: !SOLD!
D16Z6 EJ1 EX Trans S20 B000 Case
Stock Axles
Stock Open Diff
D16Z6 SI Shift Linkage
Turbo Kit:
Garret T3 60-1 .63 A/R Exhaust 4 Bolt .60 A/R 2.5 Inlet Compressor !SOLD!
Straight Line Specialties T3 44mm Wastegate Top Mount Manifold
Go Autoworks FMIC Piping Kit 2.5" all around for Tial 50mm BOV [few clamps and couplers left]
Tial 50mm BOV !SOLD
Tial 44mm Gate Purple 400 Miles !SOLD!
Large FMIC Bar and Plate good for 600hp dimensions later !SOLD!
4" Stainless Downpipe 4 bolt (does not clear radiator fan, must remove it, has some dents) !SOLD!
P28 ECU chipped and socketted !SOLD!
AEM UEGO Wideband !SOLD!
AEM 30PSI Digital Boost Gauge
Russel Oil Lines and fittings !SOLD!
Blox Black Oil Sandwich Plate !SOLD!
Prices:
Shell with stock suspension and steelies: $1500
I know im probably even forgetting stuff.
Photo Album: 93 Honda Civic HB Build 2008-2009 pictures by underoath66 - Photobucket
Current Pics of everything soon...
PRICES ARE ALL OBO NOW! JUST DONT LOW BALL ME!
COMPLETE SWAP GONE!
Top mount still here! Get it sold! Price drop to $750 Shipped
AEM Digital Boost Gauge still here! Get it sold! Price drop to $140 Shipped
Piping still here! Get it sold! Price drop to $140 Shipped [just piping will throw in the couplers and clamps I have left]
KYB AGX and Ground controls still here! Get it Sold! Price drop to $125 Shipped [rear struts no longer rebound, fronts work great]
If you see other Misc parts in the pics that I do no have posted it is possible I have them still and would like to sell them.
If shell doesnt sell, it will be receiving a heart transplant during winter.
Bottom End: !SOLD!
Hastings Rings
New OEM Water Pump
Y7 Crank Pulley
ARP Flywheel Bolts
New OEM Timing Belt
Head: !SOLD!
D16Z6 Casting
Stock Fuel Rail
Stock FPR
Stock Injectors
NGK BKR7-11 plugs
Drivetrain: !SOLD!
Stock Axles
Stock Open Diff
Turbo Kit:
Tial 50mm BOV !SOLD
Prices:
COMPLETE SWAP GONE!
hey whats up man i saw ya looked at my single campart out thred i am not sure if i coudl really use anything i see you sold you turbo... why???? and why get rid of all the singe cam stuff!!!! only thing i would really want is the bottom end and head but i dont really got money to spend i was trying to just go back to stock!!!!!!!!!!!!!!! but
big bump for probably a bad *** single cam!
What are you looking to get for the bottom end? I'll be picking up. Email me at Samwu1@yahoo.com . Thanks man.
