Sucked up some water!!
Old Jun 13, 2009 | 11:58 AM
ep3man's Avatar
Default Sucked up some water!!
so im driving to ocean city last thursday night while rain is pouring it's *** off. i have a mugen front lip so there is a hole right to my filter(cold air). as im driving i try to pass someone and it's starts to bog out. this happened about four times within 2 hours of driving. Could anything be messed up? what should i check for? thanks.
Old Jun 13, 2009 | 03:03 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Default Re: Sucked up some water!!
pull your spark plugs to see if they look wet
Old Jun 13, 2009 | 04:21 PM
Targa250R's Avatar
be professional
If the car is still running, power delivery feels normal, and it isn't making any unusual noises, then it's fine. You dodged the bullet. If you're really paranoid, run a compression test. If you bent a rod or valve, you'll have one or more cylinders with abnormally low compression.
Now get yourself a bypass valve or relocate the filter back in the engine bay where it belongs before you do some real damage.
Old Jun 13, 2009 | 08:38 PM
ep3man's Avatar
check the plugs and compression. both are fine.
Old Jun 14, 2009 | 03:20 PM
TravisCadello's Avatar
you are so lucky you didn't hydro lock your motor man! pull your plugs and change your engine oil! good luck
Old Jun 14, 2009 | 03:54 PM
ep3man's Avatar
everything is good
Old Jun 15, 2009 | 09:25 AM
simonEp3's Avatar
Nice to hear everything is ok
Side note: Did anyone else find it ironic that he was headed to OCEAN CITY and it was POURING RAIN and he SUCKED UP WATER?????
Wierd...
Old Jun 16, 2009 | 07:45 PM
2KRacing_JM's Avatar
Both Injen and AFE make a hydro shield, looks like a condom for air filters. Doesn't let water pass through, pretty neat invention.
http://www.2kracing.com/Product/8274.html
Old Jun 16, 2009 | 09:14 PM
kobeballer96's Avatar
lol man i was down therr too for senior week. i seenn a coupe of eps. bunch of boosted rsx i was with my buddies and they were drivin srt4 and sti s
aavtec
19
Feb 18, 2013 04:20 AM
The Internet Tough Guy
52
Apr 17, 2006 11:59 AM
boostjunkie757
Sep 3, 2004 01:19 PM
VTECorona
Sep 7, 2003 03:37 AM
Aeka GSR
Oct 4, 2002 11:44 PM
