Transmission & Drivetrain Gearboxes, Differentials, Clutches
clutch issue
Old Jun 13, 2009 | 11:01 AM
boosted91crx's Avatar
Default clutch issue
I have a ACT 6 puck extreme and its been great for 15k miles and countless passes, last night i went to do a 3rd gear burn out and the slicks must not have been wet all the way around and it kinda bit, i felt it right away and pushed the clutch back in, but now it slips tiny fraction off the line, i can feel it when i launch. im getting ready to swap trannys and wonder if i ruined it or if its just got a smooth spot now and i can use a roloc disk to freshen up the flywheel and PP , or should i order a new clutch kit, if so does any one know if LSD motor sport clutches are as good as ACT? they claim to be as good, offer a warranty and are cheaper. i love my ACT but its just so expensive to replace. i posted this in the drag racing forum but after 22 + views no one had a clue.
Old Jun 13, 2009 | 03:47 PM
newtype_33's Avatar
Default Re: clutch issue
act is good i dont know about lsd motorsports just do some research....
Old Jun 14, 2009 | 02:55 AM
sleepinonacreeper's Avatar
you wont know much until you pull the trans and inspect the clutch. check the wear on the pres plate and flywheel surfaces and look to see if there are excessive hotspots on both. measure the thickness of the disk and see if there is excessive chunking of the friction surface. replace whatever doesn't pass inspection. act unsprung 6 pucks and flywheels are not very expensive. i have no experience with lsd clutches. third gear burnouts are pretty rough on a clutch. i'd stick to doing longer ones in 2nd gear.
Old Jun 14, 2009 | 07:58 AM
its dead jim, its into the rivots, so back to question 2 is LSD as good as ACT? i need a clutch that can handle 330 ftibs+
Old Jun 14, 2009 | 10:01 AM
Mista Bone's Avatar
D Tranny Guru
"I warned you"...........but look at it as a good thing.
If you'd just put the GSR tranny on, 2 weeks later you'd be pulling it right back off. Sorta a blessing in disguise.
boosted91crx
Jun 14, 2009 07:06 PM
CLE
Sep 19, 2006 04:30 PM
Stunna BEN
Feb 2, 2004 06:01 PM
TegLover4life
Apr 18, 2003 10:01 AM
sensaiGen5
Jan 16, 2002 05:14 AM
