Shaking steering wheel from 40-60
Old Jun 13, 2009 | 10:28 AM
prelude_93vtec's Avatar
Default Shaking steering wheel from 40-60
So recently my steering wheels been shaking from 40-60 and sometimes at higher speeds.
My autos teacher said it could be unbalanced front wheels but I wanted to get all possibilities of this problem. I also heard that it could be the drivers side axle
Old Jun 13, 2009 | 10:36 AM
NirVTEC's Avatar
Default Re: Shaking steering wheel from 40-60
NOT when you're braking? Just cruising? Start with a balance.
Old Jun 13, 2009 | 10:53 AM
shooter93's Avatar
i have the same problem, i balanced my wheels, replaced my drivers side axle,done all but an alignment but the tires are wearing just fine.
Old Jun 13, 2009 | 11:57 AM
Just cruising, no matter if I'm floorin' it or just picking up speed it does it between 40-60 and then it chills down. I know it's not the brakes for sure
Did it fix the problem?
Old Jun 13, 2009 | 11:58 AM
shooter93's Avatar
no, it didn't!
Old Jun 13, 2009 | 03:48 PM
meev182's Avatar
how are your tires? rotate them to the back and see if the vibration goes to the seat. if you dont rotate your tires every 3-6k miles thats probably where your vibration is coming from.
Old Jun 13, 2009 | 07:18 PM
minilogoguy18's Avatar
you could have bad upper or lower ball joints. When my fronts were in bad shape the car seemed a lil unstable and didn't track in a straight line even though it was aligned and when I replaced them it fixed it.
Old Jun 14, 2009 | 12:17 AM
Yea my upper balljoint on passenger side is gone to sh*t so that could be a possibility also.
I'm gonna get them balanced tomorrow and if that doesn't work, I'll just change the UCA.
Thanks guys!
Old Jun 14, 2009 | 11:20 PM
user 9782082308's Avatar
If rotate and balance doesn't, work check your engine mounts and inboard cv's.
Old Jun 16, 2009 | 09:18 AM
Well I was driving and realized that it only happens when I'm giving gas so I'm pretty sure it's more on depth than just a balance. I'm gonna check the mounts and then replace the drivers side axle and see how it goes
Old Jun 16, 2009 | 12:00 PM
92civlude's Avatar
One or both of your inner CV joints are bad. Look for clues, grease leaking out of the boots or excessive up and down play in the shaft.
Old Jun 20, 2009 | 02:49 PM
dreamfast's Avatar
check your ball joints or your axels
Old Jun 25, 2009 | 12:57 AM
Got wheels balanced and didn't fix it so pretty sure it's the axle.
I'll let you guys know how it goes
Old Jun 25, 2009 | 07:59 AM
218luder's Avatar
have you checked your rotors? you could possibly have warped rotors
Old Jun 25, 2009 | 08:27 AM
Televator's Avatar
I'm having the exact same issue with my beater civic. Rotation doesn't work, but I also have reason to believe it could be an axle problem. There's no tire wear, and I get the typical "bad axle sound" when I got from lock to lock on the steering wheel (but it's a very faint sound). Only reason I haven't fixed it myself is because I can't seem to find any lift points on my civic. Last time I lifted it for the tire rotation, it cracked the windshield somehow....
Old Jun 27, 2009 | 01:30 PM
meev182's Avatar
did you change your upper control arm? how much tread is left on your tires? just cuz they arent worn uneven doesnt mean they wont cause a vibration...where any of the wheels bent? i think youre making this harder than it has to be.
Old Jun 28, 2009 | 03:10 AM
bluedlude's Avatar
I had the same issue on my civic. it would start to vibrate between 35 and 50 and go away at higher speed sometimes. I knew both of my axles were shot so I figured them to be the fix. till one day on the way to work they vibration got REALLY bad. I took a look at my wheels when I stopped and I could see a section of tire tread that had burst apart and steel belts were all over. replaced the tires and it was fine.
there is a jack point on the front end and i believe it is part of the radiator support. it may or may not have a tow hook still attached. it is exposed through the splash shield so you should be able to see it.
Old Jun 28, 2009 | 07:01 PM
Tires are fine, didn't change the UCA but that's on the pass. side and pretty sure that's not causing the problem. I'm almost 100% positive it's the axle
Old Jun 29, 2009 | 12:15 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Sounds like an axel for sure. Keep in mind that its not just the driver side that will cause the vibration. either side can be the culprit.
Old Jun 29, 2009 | 01:04 PM
Televator's Avatar
What model do you have? I have an '03 EM2. I looked at the manual but it said to lift the car on one of those fancy hydraulic lifts that lift the car from both sides... I'll probably take a look where you said with a flash light one more time.
Anyway....how 'bout them Preludes eh? This could warrant a move to "technical". Heh
Old Jun 30, 2009 | 10:51 PM
l.u.d.e.51's Avatar
theres a technical service bulletin out for a shaky steering wheel i dont remember how to fix it but if you know someone who has alldata or mitchell there just oem repair procedures that dealership use. but it could be ball joint. but unless you get bump steer too its not a balljoint or a tie rod end
Old Sep 16, 2009 | 09:07 PM
Update: Replaced the drivers side axle and problem fixed!! Thanks for the help guys, hopefully someone else will find this useful lol
Old Sep 16, 2009 | 09:24 PM
plushh's Avatar
alignment?
Old Sep 19, 2009 | 04:55 AM
coolharry's Avatar
useful indeed!
i've been having the same problem but from about 50-70, and the vibration got really bad under heavy breaking.
took a look under my car last night and sure enough the outer cv boot on the driver side is torn wide open.
no clicking yet, but i think i just found a project for my next day off.
is it worth it to just do the driver side, or should i do both at the same time? and what am i looking at, difficulty wise, if i do this in my garage with just a jack and stands? (man do i miss having access to a lift!)
Old Sep 19, 2009 | 10:50 AM
Originally Posted by coolharry
useful indeed!
Under braking it's most likely a brake problem; warped rotors, etc.
The axle wasn't that bad at all except for the axle nut and the snap ring. I also did it on jackstands. What I did was beat the **** out of the bolt with a hammer and chiseled the corners to brake it loose and then used a breaker bar with a cheater bar to get it loose. And for the snapring, you gotta take a big flathead, stick it inbetween the axle and tranny housing, and hammer at it. You'll see what I mean when you get there
Mashi2Choco
Suspension & Brakes
18
Feb 24, 2010 02:55 PM
BLUE EH3
11
May 9, 2006 05:50 AM
Rob.
14
Apr 11, 2006 12:16 AM
Weapon_R
Feb 25, 2005 11:09 PM
iwhichisme
Nov 11, 2003 03:06 PM
