Cams= Good Power
Old Jun 12, 2009 | 10:31 PM
dntnedvtec's Avatar
Default Cams= Good Power
Okay, I am need of a good power upgrade. (bout time) I was looking at cams, but there are so many to choose from. I want a set, that makes good power top end, mid range sure, but daily drivability. I would like to retain stock springs and retainers, but if its an upgrade, so be it. I wonder if I can keep the bottom end stock? Would I need to up grade as well??
Intake manifold is will be one the way after cams. crap, I for got the tune...
APP: 2000 B20
Old Jun 13, 2009 | 11:40 AM
lobudgetr's Avatar
Default Re: Cams= Good Power
When upgrading the cams springs and retainers are a good idea. When I had and LS i used SLR cams, they worked really well, made power to 8000 RPM but also drove well as a daily driver.
Old Jun 13, 2009 | 01:13 PM
DKYamada's Avatar
if your not looking to change spring and retainers itr or ctr cams might be the way to go
Old Jun 13, 2009 | 01:49 PM
Targa250R's Avatar
be professional
Regarding the bottom end: If you plan on revving higher than stock - which you'll probably want to do in order to take full advantage of bigger cams and a re-tune - I would highly recommend at least upgrading the rod bolts unless you enjoy spinning rod bearings due to rod bolt stretch. The same problem plagues LS-VTEC and B20-VTEC bilds with stock bottom ends; the wimpy original rod bolts can't handle the forces generated by revving above 7200 RPM constantly.
Those aren't going to work too well in a non-VTEC head . . .
Old Jun 13, 2009 | 05:11 PM
sucka4eg's Avatar
Thats why god invented ARP =P
Old Jun 14, 2009 | 02:52 AM
DKYamada's Avatar
damn didnt read it right haaha
Old Jun 14, 2009 | 02:51 PM
dntnedvtec's Avatar
SLR?? how much power did you make? Seems like springs/retianers are a must. I would rather be safe then have valve float and destroy everthing. looks like I should be ready. Thanks guys.
ahthisguyhere
12
Feb 12, 2006 01:27 PM
VtecDA9
105
Jan 27, 2006 05:35 AM
riceball777
Dec 6, 2003 10:48 PM
RobbieG35
Jun 10, 2003 05:55 PM
pregunta
Dec 24, 2001 07:19 PM
