Relay Buzzing on K20 swap with relocated battery
Old Jun 12, 2009 | 03:35 PM
.dave's Avatar
i HAS questions ?
Default Relay Buzzing on K20 swap with relocated battery
Even though Hondata recommended not doing it, I saw that people on K20a.org had relocated their batteries to the trunk. I ran 1 gauge wire from the alternator to the battery and 4 gauge from the starter to the battery.
When I turn the key to the 'on' position there is a buzzing coming from the relay under the dash. I checked all the grounds on my engine with no change. Thinking it was the battery, I hooked the charger I have up and put it to the jump start mode. Flipped the key to on, no buzzing, fuel pump comes on.
So I drove over to Sears and bought a new battery. Came back, installed it, flipped the key, buzzing again.
Should I abandon the idea of relocating the battery to the trunk, or do you think there is something else going on?
Old Jun 13, 2009 | 09:14 PM
.dave's Avatar
i HAS questions ?
Default Re: Relay Buzzing on K20 swap with relocated battery
Spent all day with a multimeter under the dash. It looks like the main relay is bad and the starter is shot as well. I should have replaced the starter anyways seeing as the swap sat for quite a while from when the car was wrecked until I bought it.
nxtNMkillaB
Sep 12, 2012 04:24 PM
Fnix
Jun 12, 2012 07:21 AM
fw190bvi
Jul 27, 2007 09:52 PM
wambus
21
Jun 10, 2005 11:02 AM
