front lca's torgue specs?
Old Jun 12, 2009 | 01:29 PM
lubmyinteg's Avatar
Icon2 front lca's torgue specs?
what up ya'll
jus curious to know what the oem front lca torgue specs are for a 98 usdm itr?
thanx...
Old Jun 12, 2009 | 01:58 PM
SlapSmak's Avatar
Default Re: front lca's torgue specs?
Flange bolt (LCA to frame mount) 47ft lbs
LCA to spindle (pass through bolt with self locking nut) 47 ft lbs
Lower ball joint nut 43 ft lbs
tie rod nut 32 ft lbs
Old Jun 12, 2009 | 05:28 PM
Tweakmeister's Avatar
TORQUE UNDER LOAD
If the car is on all four jack stands, you gotta take the floor jack and jack up that corner to where the hub would sit if the car was on the ground (I usually just jack until that corner of the car is off the jackstand).
Failure to do so with result in torn rubber bushings and/or them wearing out very quickly. You'll probably also get a nice clunk/creak around turns.
Old Jun 13, 2009 | 08:33 AM
Ill's Avatar
Ill
Originally Posted by Tweakmeister
TORQUE UNDER LOAD
Excellent info!
Sounds like the OP also needs to buy the Helms manual. A bit pricey, but an important (and I think necessary) addition to any R that will be worked on.
That_Delsol_Guy
Dec 30, 2015 05:55 AM
droogie
Suspension & Brakes
Dec 14, 2011 07:05 AM
MindBomber
Suspension & Brakes
20
Sep 13, 2010 10:07 PM
Steppin Razor
Suspension & Brakes
Mar 19, 2007 03:15 PM
Tim2179
Aug 1, 2006 05:39 PM
