ac compressor replacement
i have a really simple question.
have someone of you changed the ac compressor from underneath the car ?
i know that the way to be usually done is to remove the power steering but if i have 2 carjacks i can easy go under the car and swap it since there is nothing under the compressor but just empty space.
well i actually wonna fix it
i live in South Florida , its god damn hot
but i was just wondering if do it this way do i have space to reach and loose the belt ?
well i jacked the car today and went underneath to see and it does not look optimistic.... if i remove the 4 bolts there is space and the compressor is gonna come out , but there is no way to reach from anywhere to loose the belt
i guess that im gonna start reading in the manual about the regular methor trough removing the power steering ...
why are you afraid of your power steering, its like 2 bolts. take the pump and the reservoir together and lay them off to the side, then there's plenty of room to do whatever you need to do.
chieftaco
10
Oct 11, 2009 03:38 PM
90, 98, 99, ac, belt, car, civic, complressor, compressor, cost, honda, remove, repair, replacement, replacing
