Suspension & Brakes Theory, alignment, spring rates....
Typical GC + Koni Yellow setup questions - CRX
Old Jun 12, 2009 | 10:36 AM
raene's Avatar
Default Typical GC + Koni Yellow setup questions - CRX
Hey all,
I have a CRX that I primarily drag race but also occasionally autocross. I do drive it on the street but I don't drive it daily so I don't care about ride harshness all that much. I have 24.5" slicks on Lenso VPDs, and the suspension on the car is so bad I can't manage better than a 1.9 60'.
Just wondering,
a) Is there a minimum/maximum spring rate that the Koni Yellows can "successfully" dampen without asking the shock to do too much,
b) What type of spring rates would be "recommended" for my setup - I see the Omni coilovers running 18k rears with 12k fronts which I translate as something like 220/350 lbs FR. Why are these so light - I was considering 500/600 lbs FR, and my friend's HB is running a 500/700 combo,
c) Where are racers getting their higher spring rates from - all the package deals I see are in the 250-350 lb range.
Thanks guys... just trying to consider my options and learn a bit more about a "good" suspension setup
Old Jun 12, 2009 | 12:49 PM
xd69's Avatar
Default Re: Typical GC + Koni Yellow setup questions - CRX
b) Since you drag race, you are going to want some really stiff rear springs. I would recommend somewhere in the 700 lb/in range. And your conversions from kg/mm to lb/in are WAY OFF! 18k = 1007.98 lb/in and 12k = 671.96 lb/in.
c)Those really soft springs are all OTS GC springs. Most people opt for custom rate springs where you can get whatever rate springs you want/need.
Old Jun 13, 2009 | 03:44 PM
raene's Avatar
Ahhh, I didn't know you could get the packages with custom rates... thanks for the conversions too, that helps a lot
Old Jun 13, 2009 | 04:38 PM
STOCK_SOHC_DX's Avatar
remember Koni sports are valved for 550 Lbs so your gonna need to get them re-valved unless you have the race shocks.
Old Jun 14, 2009 | 08:37 AM
Jenkinsal2's Avatar
I would get the Race valving Its like SSP or something along those lines. You can get custom springrates as well check the marketplace for some good deals on a package deal.
Old Jun 15, 2009 | 08:38 AM
raene's Avatar
OK thanks! I didn't know that, that's what I was looking for
Old Jun 15, 2009 | 08:55 AM
irev210's Avatar
my crx is running 450lbs front / 800 lbs rear on koni yellows
Old Jun 15, 2009 | 09:59 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
And how is that working out for you? Your post doesn't really help the OP all that much.
Destructive-
Suspension & Brakes
15
Sep 28, 2008 08:36 PM
kisceneret
Suspension & Brakes
Jan 29, 2008 07:47 PM
litterbox
May 25, 2004 08:46 PM
Dynamix
16
Dec 11, 2002 02:48 PM
Dynamix
Aug 10, 2002 12:43 PM
