Civic Cx w/ jdm b16 throws knock sensor and vtec solenoid codes? No reason.
i have a 94 Civic cx hatch with a jdm b16 and running a pr3 ecu. I have the vtec and knock sensor wired to the ecu seperate. But after it reaches operating temp, it'll throw a code for the knock sensor and vtec solenoid. Will the vtec solenoid code come up if its low on oil? And is there anyway of fixing the knock sensor code with out running a p28. Thanks for any help.
I am having the same problem as you I have a 91 crx with a build ls vtec i am having problems with code 2 23 24 with a pr3 obd o ecu any help
91EF_Si
Sep 25, 2007 08:40 PM
Raunch
Nov 8, 2003 10:05 PM
