wiring question SOS
wiring question SOS
im doing a b16 swap AND a auto to manual swap can i still use the same wiring harness???.........i have a 95 civic ex that had a 1.6 SOHC vtec. any help will be greatly appreciated.
Re: wiring question SOS
You want to use the engine harness and ecu from the 1.6l sohc?
i have the ECU for the B16 that i know that i have to use but i want to know if i need to use the B16 wiring harness. im talking about the inside wiring harness....also the engine is a JDM SPEC
Oh alright.
Your going JDM on the b16?
You need a obd1 b16 engine harness.
You already have the vtec wires setup on the shock tower from your sohc vtec.
Your ready to go.
Your ready to go.
yeah i got the engine harness all set up but im having trouble with the inside wire harness i read online and i heard that all i needed to do to the auto to manual swap was to remove the clutch relay and set it up on the automatic harness and everything else is the same...is this correct?
joelmatt89
01-27-2009 08:12 PM
