which spark gap. b18c1
Brk7e for sure I had a gsr block with .038 gap. It depends on the gap put it on a dyno and check for any misfires. Also rule of thumb the higher your compression tighter the gap. Unless you're running an aftermarket ignition system
good question, i dont really know. with MSD you get a better more consistent spark, so in theory i guess you could raise the gap without harm because of the more intense spark output. just to be safe set it at the recommended gap for now. someone with a little more knowledge please correct me if im wrong?
